fiat grande punto
Hi Guys
I need some help, i've bought some white led parklight bulbs and then got an error light on my dash, so i've read that you must use a resistor with it, so iwent to a electrical shop and changed the excisting resistor with a better one, but when i put the led bulb on the driver side, the bulb flashes, but when i put it on the passenger side and the original bulb in the driver side it work perfectly, but then when i put the led in the driver side with an led on the passenger side, both flashes, so what can i do next to get these led bulbs to work, do i need to wire up another resistor on each bulb, so that there is two resistors per bulb
please help
thanks
fiat grande punto
please help
thanks
fiat grande punto
