Yeh you do have an intercooler... you can upgrade the intercooler like Swans-GP said. But there is alot of things to consider, trust me, im looking at doing it at the mo...
Yea my intercooler there!!! not much of 1 the intercooler on a scooby is mounted on top of the engine and the bonnet scoop pretty much seals to it for maximum cold air feed
Would prefer a FMIC than TMIC, like the smoothness of the bonnet, dont want to drill a gaping hole out of the bonnet! Downer of a FMIC is that there easy enough to chipped from the crap from the road. But advantage is that it gets more air.
thanks, well atm its best to be a FMIC unless your wanting to stick a bonnet scoop on your gp, yet again the no room to have a TMIC on a gp. so best to see if you can get a bigger 1 to sit in the front
Well they need measurements, and I think they will be the same to be honest, but ill leave that to them. I reckon if there were 5 of us it would be around £300-£500 each.... I think but that is a random guess...
FMIC's will give you colder denser air going into the engine which gives you more power compared to a TMIC which can suffer from heat soak as the heat off the engine rises. FMIC's tend to cause a bit more turbo lag than TMIC's as TMIC's take less time to pressurise than FMIC's which means the turbo spools up faster.
