you must have a water leak then!
I must have an extremely large bottle cause i've only filled mine up a few times
Thought of that, but there's no signyou must have a water leak then!
The manual says it hold 2 litres.I wish I could say the same. Mine holds about 1.75 litres.
Belatedly I need to explain that Lui's solution, as explained by me, needed to be modified. The reason was that, because Fiat's water bottle has a loose-fitting neck, once the system was activated, a siphon was set-up and all the fluid from the top (auxiliary) bottle leaked out at the neck of the original bottle. The final solution (it has been in place for over a year) was to enable the bottles to work simultaneously but separately. The original bottle feed the back window and passenger side of the windscreen, the new one (cannibalised from a Mark II Punto) cleans the driver's side. Problem solved!Yep, my GP had just this problem - also, the washer reservoir was so small that I would run out of washer fluid after 10 miles!
Problem was fixed by Lui's LB Autos in Somerton Lui abandoned the old jets, affixed new (adjustable) ones, and installed an extra reservoir in the vast empty space in the engine compartment. This feeds the original reservoir bottle, so I now have 3 times fluid capacity, all fluid goes onto the windscreen (instead of all over the place), and I can adjust the jets to my heart's content.
I went to Lui after attempting to get 3 different Fiat dealers to understand the problem (and after being asked by Fiat Customer Care "why did you buy the car if you didn't like the washers"!!!) None would admit, initially, that there was a problem and then claimed that nothing could be done. However, Lui rose to the challenge.
Please note: I have no connection with Lui other than being a very satisfied customer!!!
