hey, im beginning 2 hate my fiat more and more had it back a week and now the interior fans are humming anyone else had this problem??
thanks Lewis
thanks Lewis
Mine had exactly that problem, bloody leaves get everywhere!!! Solved the problem in the same way too, or my girlfriend did anyway.....mine did this for a while but found it was just a leaf and it blew out when i put each blower on full, worth a try.
The training is there & so is the equipment to carry out the work however let us not forget the biggest problem of all, the dreaded 'intermittent fault' !
fiats arent pefect, they are cheap. They go wrong a bit and you need to fix them yes its anoyng but to be honest i like it, i like fixing my car, it creates and bond between you and your car. making the car much more loveable, gives it more personality than a different marque.
I the dreaded 'intermittent fault' !
In your case I take it that plugs/leads/ECU has been checked?
Like the clunking from cold start that no-one has solved yet:bang::bang::bang:
OK
just got off the phone with the Service Manager, they are going to have a long hard look at it, so they gonna keep it and give me a Courtesy Car. BUT, will have to wait till next Tuesday. If they have it for a week, I don't mind, as long as its fixed when they finished.
i took my car in with a misting up fault and they told me there was nothing wrong with it, i had a look and found that the recuculate was stuck on so i phoned them and booked it back in and when i pointed them in the right direction and amazingly there was the fault and it was fixed sometimes its better to try check it out yourself if you know how.
Lewis
would of been first place to look I would have thought?
