| Thread Tools |
![]() | #1 |
Posts: 875 Thanks: 21 Trader Rating: 0 ![]() | Disconnecting Battery Can I disconnect my Grande's battery for 5 mins or so without having to reset anything or enter any codes. Just want to clean all the foul spray grease off the battery, clean up the terminals properly with a post cleaner/wire toothbrush and put some petroleum jelly over the clamp/terminal.
__________________ ![]() ![]() 1998 Fiat Punto 60 S 1.2L SPi ![]() ![]() 2006 Grande Punto Dynamic 1.2L 8V |
![]() | #2 |
Posts: 29,985 Thanks: 1063 Trader Rating: 0 ![]() | Re: Disconnecting Battery just the clock |
![]() | #3 |
![]() | Re: Disconnecting Battery Can I disconnect my Grande's battery for 5 mins or so without having to reset anything or enter any codes. Just want to clean all the foul spray grease off the battery, clean up the terminals properly with a post cleaner/wire toothbrush and put some petroleum jelly over the clamp/terminal. I will be making a Guide up in the next week or so (on 3 day weeks from next week so i will have time to do it) showing the other places that could do well to have a clean up and a smear of suitable grease ![]() you shouldn't need any codes as such as the radio is paired with the body computer (saying that you should have the radio passport anyway) |
![]() | #4 |
Posts: 875 Thanks: 21 Trader Rating: 0 ![]() | Re: Disconnecting Battery yep take the earth clamp off first I will be making a Guide up in the next week or so (on 3 day weeks from next week so i will have time to do it) showing the other places that could do well to have a clean up and a smear of suitable grease ![]() you shouldn't need any codes as such as the radio is paired with the body computer (saying that you should have the radio passport anyway) How's this sound? https://www.fiatforum.com/car-care/1...-terminal.html Looking forward to the guide sounds good ![]()
![]() | #5 |
Posts: 29,985 Thanks: 1063 Trader Rating: 0 ![]() | Re: Disconnecting Battery |
![]() | #6 |
![]() | Re: Disconnecting Battery Good stuff. Where can I find the earth clamp is it on the wing near the battery? How's this sound? https://www.fiatforum.com/car-care/1...-terminal.html Looking forward to the guide sounds good ![]() the earth clamp is on the battery (the quick release lever) can't see a problem with that although i tend to use real Coppaslip as that wont wash of and its conductive.. I'll try to upload the correct pictures for you T are you after the one with the greasy nipple again? |
![]() | #7 |
Posts: 875 Thanks: 21 Trader Rating: 0 ![]() | Re: Disconnecting Battery I was thinking about coppaslip ![]()
![]() | #8 |
![]() | #9 |
Posts: 29,985 Thanks: 1063 Trader Rating: 0 ![]() | Re: Disconnecting Battery I use clear 'innhibitor' spray. |
![]() | #10 |
![]() | #11 |
Posts: 19 Thanks: 1 Trader Rating: 0 ![]() | Re: Disconnecting Battery is this a time dependent thing? I have a fiat 500 (08) and need to remove the dash trim for repair, but will the car tolerate negative terminal disconnection for say 24 hours, with only a clock reset necessary. thanks for help
__________________ *********************************************** dead ebay links are evil ![]() and some info too, so in 2 years time, it's still helpful ![]() *********************************************** |
![]() | #12 |
![]() | Re: Disconnecting Battery only the clock will need a reset as far as i know (check with the 500 mob about the radio but i assume its the same as the GP with the paring with the body computer) over half an hour or so it will also reset the ECU so might run a bit strange for 10-20 miles whilst it relearns its settings but after that it will be fine ![]() |
Thread Tools | |
Mouse Keeps disconnecting itself | jamie86 | Computing | 15 | 06-10-2008 08:22 |
![]() | alexGS | Uno | 8 | 20-08-2008 00:37 |
![]() | bluepunto2 | Punto (Mk2/2b) | 6 | 04-04-2008 14:06 |
![]() | dave88sw | Punto (Mk2/2b) | 4 | 20-03-2008 01:49 |
![]() | deanbean502 | Punto (Mk2/2b) | 13 | 26-12-2005 15:08 |
