Old 25-10-2008   #1
GPS Multijet 1.9 Orange
mehstg's Avatar
mehstg has donated!
OBD socket
Just a random one to supress my curiosity. Where is the OBD socket on the GP. I remember on my old Mk2 it was in the fusebox by the drivers right knee.
P
Do Not Click Here
Quote Originally Posted by Vimto Rolf View Post
i play 12 string ass mostly anyhow.
Quote Originally Posted by punto_matt View Post
It was always obvious you swung that way but kudos for finally admitting it
mehstg is offline Reply With Quote Quote
Old 26-10-2008   #2
Banned
punto_matt's Avatar
punto_matt has donated!
Western Samoa
Re: OBD socket
same place
punto_matt is offline Reply With Quote Quote
Old 26-10-2008   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: OBD socket
Eobd
Old 26-10-2008   #4
mehstg's Avatar
mehstg has donated!
Re: OBD socket
same place
I didn't think the fusebox was there anymore....will have to go out and have a look later.
P
Do Not Click Here
Old 26-10-2008   #5
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: OBD socket
Quote Originally Posted by mehstg View Post
P
no the fuse box is in the glove box but the EOBD is by your right knee
Massive gash
Just a little touch up
Old 26-10-2008   #6
Re: OBD socket
I havnt found the fuse box yet, seems well hidden. But the OBD port is hidden under a trim panel on the front of the dash in front of your right knee as Andy said. Theres a small pocket in the trim panel with a hole at the top. Open the door, put ur fingers in the hole and give it a really good tug straight toweards you and it should pop right off. Its quite worrying how much force is needed but it seems the panel is up to it.
98dizzard is offline Reply With Quote Quote
Old 26-10-2008   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: OBD socket
Quote Originally Posted by 98dizzard View Post
5 he breaks one of the 2 clips at top of EOBD panel cover
Fusebox is behind glovebox (to the left often behind metal bracket)
Old 26-10-2008   #8
mehstg's Avatar
mehstg has donated!
Re: OBD socket
Haha...fraid ur going to lose your fiver. I'm not actually going to take the panel off.....was just curious as to where it was!
P
Edit: By the way, another curiosity....what is the relevance, if any, of 14086?
Do Not Click Here
Old 02-11-2008   #9
Re: OBD socket
Quote Originally Posted by T14086 View Post
As the techie you are, how often do they break off?
Old 02-11-2008   #10
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: OBD socket
i'm not techie
trick is to ease the panel of gently at the top (pull it from the bottom & it will break the top clips) then once off put a 'dab' of grease on the top clips...next time you remove it it will come of easily
Thanks mehstg thanked for this post
Old 21-02-2010   #11
GP Abarth One Day!!
Dave UK's Avatar
Dave UK has donated!
Re: OBD socket
Oops,
Made the mistake of breaking both clips!
Time to get the superglue out!
Dave UK is offline Reply With Quote Quote
Old 21-02-2010   #12
Trader Rating: 2
colin79666 has donated!
Re: OBD socket
Quote Originally Posted by powerful_rogue View Post
Oops,
careful not to glue it so it can't be taken off without causing further damage
might want to buy a replacement cover
colin79666 is offline Reply With Quote Quote
Old 21-02-2010   #13
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: OBD socket
Oops,
cha-ching! send me the money
I prefer to use a hot glue gun for the clips (they are only about 5-8) and dont forget a little grease on the clipsbefore you fit the cover to help it come off next time
Old 21-02-2010   #14
MiTo 155
alexh365's Avatar
Trader Rating: 2
alexh365 has donated!
Re: OBD socket
Still fits nicely with one superglued clip......cant wait to break the other.
Chances are when I do break the other I'll unclip the EODB socket from its holder and cable tie it further down so I can get to it without removing the stupid panel....
Which on LHD does perform a job of covering the fuse box...
alexh365 is offline Reply With Quote Quote
Old 21-02-2010   #15
GP Abarth One Day!!
Dave UK's Avatar
Re: OBD socket
Found some super glue in the draw and it seems to have done a pretty good job!
Sods law that the engine light had gone out before I had chance to connect it!
Just curious, how much do replacement covers cost?
(T) OBD II Cable punto60_s Stilo 15 01-05-2008 16:33
(T) obd 16 pin socket locke Bravo / Brava 3 22-11-2007 23:48
(G) Brava JTD105 OBD Socket CicoJTD Bravo / Brava 16 21-10-2006 17:24
(T) OBD Socket Tim T Stilo 5 19-07-2006 20:00
(G) Does a 2001 Brava have an OBD Socket? ciddy Bravo / Brava 8 14-06-2006 09:27
