Just a random one to supress my curiosity. Where is the OBD socket on the GP. I remember on my old Mk2 it was in the fusebox by the drivers right knee.
P
P
same place
I didn't think the fusebox was there anymore....will have to go out and have a look later.
P
I havnt found the fuse box yet, seems well hidden. But the OBD port is hidden under a trim panel on the front of the dash in front of your right knee as Andy said. Theres a small pocket in the trim panel with a hole at the top. Open the door, put ur fingers in the hole and give it a really good tug straight toweards you and it should pop right off. Its quite worrying how much force is needed but it seems the panel is up to it.
As the techie you are, how often do they break off?£5 he breaks one of the 2 clips at top of EOBD panel cover:devil:
Fusebox is behind glovebox (to the left often behind metal bracket)
careful not to glue it so it can't be taken off without causing further damageOops,
Made the mistake of breaking both clips!
Time to get the superglue out!
Oops,
cha-ching! send me the money:devil:
I prefer to use a hot glue gun for the clips (they are only about £5-8) and dont forget a little grease on the clipsbefore you fit the cover to help it come off next time
Hi guys, any idea where I can order a cover from? I managed to break both of the clips! Ooooops!
