Old 04-11-2008   #46
Banned
punto_matt's Avatar
punto_matt has donated!
Western Samoa
Re: Dump valve?
GSR and map and your as far as you can go on the standard turbo.
punto_matt is offline Reply With Quote Quote
Old 04-11-2008   #47
Re: Dump valve?
yea so I believe thats y im asking if putting a adjustable wastegate will allow you to get anymore out of it. Has having map and GSR made much differences to acceleration?
The more you've got the more you want!!!
2008 Fiat Grande Punto Sporting T-jet in Carribean Orange with full leather, tinted rear 3 and blacked out rear lights, vinyled bumper and sprayed grilles. Currently dumping like a good 1 lol
Mid Wales meet 28th feb 2009 whos in???
Repsol Joe is offline Reply With Quote Quote
Old 04-11-2008   #48
I Need Beer
allanhelen's Avatar
allanhelen has donated!
Re: Dump valve?
Quote Originally Posted by punto_matt View Post
Ballcocks is all i can say to that mate
Peter does good work on FIAT engines and his bits are well proven and i will not knock what he can do to leave you with a reliable car at the end of it and to enhance what you have it would be a very good start.
But once you have done a remap and induction kit it is modified so no longer a standard Turbo so is that the end of the road is that as quick as you can get a Turbo GP?
You can do what the hell you want to a modify a standard car the only limit is your imagination and the depth of your pocket
No FIAT's any more and nothing else sensible either
allanhelen is offline Reply With Quote Quote
Old 04-11-2008   #49
Banned
punto_matt's Avatar
Western Samoa
Re: Dump valve?
No because the turbo cannot physically give any more. Yes it feels alot quicker now. Pulls alot better through all the gears and suprised alot of people.
Old 04-11-2008   #50
Banned
punto_matt's Avatar
Western Samoa
Re: Dump valve?
Quote Originally Posted by allanhelen View Post
Say it all you want. Fiat have done it intentionally to stop it being quicker than an abarth. Im not saying its as quick as you can get a turbo GP you just need to change to the abarth turbo to get more power out of it.
Old 04-11-2008   #51
Re: Dump valve?
If it was on a tJet then maybe but on my Turbo Cinq it definatly is not pressure backing into the turbo as that makes a very different chattering noise and my T15 would have disintegrated by now and is not a light flutter that is the definatly the wastgate.
But there again it is a different animal 1.2 bar of boost, a turbosmart dump valve and a Greddy EBC
All the Tuner's I've spoke to, or read articles by, state wastegate chatter is a myth. I was going to quote Wiki, but it says wastegate chatter does and doesn't exist.
My Cossie-spec T3 Turbo runs over 1bar boost, and even with a dump valve I could get a small amount of 'chatter' when lifting off just before peak boost. I decided I preferred it, so I binned the dump valve and pipework.
It's still going strong 2 Years later.
D4nny8oy is offline Reply With Quote Quote
Old 04-11-2008   #52
I Need Beer
allanhelen's Avatar
Re: Dump valve?
Higher boost, balanced and beefed up cank, flowed Head, bigger injectors, free flow exhaust, oil cooler and a piggy back ECU will blow any standard FIAT car into the ditch The problem with GP's is there are new and faster versions are available as standard so you can get more by buying a new car.
But if you look at the depreciation you will have suffered on your TJets thanks to the current market and look at the the differential compared to buying a new Abarth if you are power hungry it is making more and more sense to tune up what you have if you intend keeping the car
Quote Originally Posted by D4nny8oy View Post
Depends on how operate your wastgate and electronic dump valve closed throttle = wastgate and dump valve operates in 0.08 seconds so never any back pressure in turbo above normal boost pressure
= tissssshhh & flutter
Old 04-11-2008   #53
Re: Dump valve?
Like this-
"Flutterdump" lol. Who coined that phrase?
Old 05-11-2008   #54
Re: Dump valve?
Be great if u could get the turbo sounding like that on a T-jet lol
Old 05-11-2008   #55
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: Dump valve?
Flutter dump FTMFW! .
Although it is ruining your performance lol.
ChrisUK is offline Reply With Quote Quote
Old 05-11-2008   #56
Re: Dump valve?
No at the end how it should sound
Old 17-12-2010   #57
Ireland
Re: Dump valve?
Can this be done by only taking the small pipe out (with the 90 degree bend) where the air will come out rather than take the engine cover off as well?
Just curious because im going to do it for now.
And what sort of filter or cover would do for it? Got some tape for where the air would be going back in.
Steve-o_bc is offline Reply With Quote Quote
Old 17-12-2010   #58
South Sandwich Islands
Re: Dump valve?
Quote Originally Posted by Steve-o_bc View Post
Doesn't sound anything like an atmospheric BOV if that's what you're hoping, but yeah, stick some tape over the bypassed and thats fine.
It sounds annoying after the dump though as the *pop* of the valve is just as loud as the release..
will do until you get a proper BOV
TJet120TJet is offline Reply With Quote Quote
(G) dump valve R12MUS Punto (Mk2/2b) 1 29-04-2008 17:15
(T) Dump valve or not?? puntoman1 Punto (Mk2/2b) 6 24-04-2008 19:42
(T) which dump valve? JAT'85 Punto (Mk2/2b) 1 15-03-2007 21:02
new dump valve..... charlieboy Leisure Lounge 5 23-07-2006 15:08
(T) 2 dump valve? Metro_vvc Uno 5 31-01-2006 08:43
