I tried falken 512's on the front of mine last time, and they were so bad, I was tiptoeing around in the wet, and even took my car to the garage to get them to check all the front suspension out, as I thought something must be broken! the mechanic said it was fine, and to change the tyres, I threw the falkens away (well, in my shed incase I get punctures!) and put on some goodyear F1's, and its transformed the car, back to its usual self again, I have grip!
I really rate the bridgestone potenza's too..... there's a reason they are standard equipment of the like of porshes, astons ect... but they are so expensive...
I've always heard good things about the toyo's, but never tried them...
pirelli p nero's are good too.... I had them on the vRS
federals? well I've used them on the GP too, and they gripped ok, but fell apart!
they went oval, and caused all sorts of vibrations.... could have blown, I wouldn't reccomend! threw them away before they wore out too!
anyway, my advice in order of personal preference...
1) OE bridgestone potenzas RE050A (don't confuse this flavour with other brdgestones!)
2) Goodyear eagle F1 (GSD3?)
3) pirelli p nero's
4) toyo's... (on reputation, i haven't tried them, but certainly would)
avoid:
avon's (ZZ3's) they grip ok, but I had a pair of them fall apart and crack (on the inside! found after I had them removed for vibration/oval problems like the federals..)
federals/ most cheap makes..... maxxis were tested by autoexpress recently, and they basically said "ditchfinder".......
