Hi, just wondering if any of you GP owners out there, have had this problem before?
I was checking my oil, and when I checked the dip-stick for the level, there was no oil deposit on the stick? I did this plenty of times, and still nothing?
Now this is the interesting part. I have had a service on the vehicle (oil and filter change ect…) in April 08, and for argument sake I had only done 7000miles, and now further down the line in August 08, I have done 10,000miles.
So by doing 3000miles within a 5month period, it appears that I have no oil? I understand that the dip-stick does not hit the bottom of the oil tank. So there is still some oil in there.
I did not receive a warning light on the dash to check my oil, it was just one of those random occasions that I decided, that I should really check my oil?
No oil is being left on the drive, so safe from leaks.
I am not noticing any blue smoke coming from the exhaust?
Now, I have filled up the oil tank with the recommended grade in the hand book, and went straight to the dealer, to see a mechanic. I told him the problem above, and he reckons that these cars burn oil quickly, and should be topped up with oil quite regularly. His assumption (forgive me if I am wrong) is that for every 1000km the oil burns a litre! That is only 621miles! And the tank only holds around 2.8litres of oil! So this seems ridiculous to me, and seems that I have been made a fool!
I am wondering if anyone else has had this problem. Or knows what problems may be potentially happening?
FYI, I don’t go hell for leather in my car, and usually use it to commute to work ect…. It is a 07plate GP, 1.4 16v Sporting, if this makes any difference?
Thanks for your help or advice in advance,
Dave
Dave
