The GPS uses the Vauxhall gearbox and the Q2 does not fit.
I went to an Alfa speacialist to double check and unfortunately it will not fit.
They had fitted them to Stilo Mjets so if the Bravo uses the same gearbox the Q2 should fit. The biggest issue with the Stilo is that the subframe had to be removed to access the gearbox adding to the cost.
