i did mine topday not joking took 1.5 hous to doo all four
jack car takle wheels off unclip brake lines undo aintroll bar link undo hub bolts pull hub out and rest it it will support it self then undo top mouth in engine bay strut come out then clamp springs 19mm socket on top of strut off they come new one on put it back togeather
rear was ven easyier jack car up put it on axe stands jack up the rear beam just to support it then undo lower damper bolt push damper out way lower rear axle pull springs out take rubber mounts off put them on new ones then put it back togeather
just a rought guide but it really easy
