im Axle Specialists
Old 03-02-2008   #1
GP Idle Speed
Has anybody had a problem with their GP (1.2 Active 56 plate) - mine has been back to the dealer 3 times for a problem where the idle speed drops of the gauge and causes the car to stall at junctions etc. This seems to occur when I've been caught in heavy stop-start traffic (rush hour etc) - the idle speed drops to approx. 400rpm and it stalls.But each time I've phoned the dealer and reported the fault, it has cleared up by the time I've taken the car back to them - it lasts for a couple of days. It's just been for it's yearly service (I do low milage 8k per year) and they couldn't find anything wrong.
Two day's after the service, it did it again!! and it lasted for about 36 hours - everything is now fine......
Has anybody experienced similar with their Grande Punto ?? Can anybody shed any light on this for me ??
AJKelly is offline Reply With Quote Quote
Old 03-02-2008   #2
put a towel on it
Jamie's Avatar
Jamie has donated!
Re: GP Idle Speed
fine for me i havnt heard of it doing this before though fuel starvation?
i did have a clang on start up though. HID ballast rattling my bad!
cleaned-uk.lowlifeuk
Jamie is offline Reply With Quote Quote
Old 03-02-2008   #3
Talking Re: GP Idle Speed
Hi. It could be a problem with the throttle body and associated wiring. I had a stilo which did that, luckily the car stored a fault code in the ECU and the garage knew what the problem was. It happened three times in a year! It wasn't a long repair job but the first time it happened the part had to come from italy via a slow donkey ride. My current Ford Focus had the same problem and the car ran really badly sometimes. No fault code this time but after a word with a guy from Ford technical it was fixed. Apparently some of the wires inside the insulation material can break causing intermittent breaks in the circuit. hope this is a help.
stiloactive is offline Reply With Quote Quote
Old 03-02-2008   #4
Re: GP Idle Speed
PS. mine hated stop start traffic and quick stops where the revs drop off quickly.
Old 03-02-2008   #5
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: GP Idle Speed
my eyesight aint that bad!
Old 04-02-2008   #6
Re: GP Idle Speed
Quote Originally Posted by grandeJ View Post
Thanks for that - I also get a clang/rattle sometimes when starting the engine, only from cold start.
Old 04-02-2008   #7
Re: GP Idle Speed
Quote Originally Posted by stiloactive View Post
Thanks for that - any info is greatly appreciated.
It didn't show any error codes in the ECU, that's what had two different main dealers scratching their heads!! It seems to re-set itself after a couple of days, but it has happened four times now and it does seem to be stop-start traffic that sets it off.
Old 04-02-2008   #8
put a towel on it
Jamie's Avatar
Jamie has donated!
Re: GP Idle Speed
Quote Originally Posted by AJKelly View Post
turns out it wasnt the ballast, started this morning and got the clang, and yeah. only from cold
Old 09-02-2008   #9
Re: GP Idle Speed
There's an EFI ECU update for certain models (inc 1.2 8v) which may correct these cutting-out/low idle issues.
D4nny8oy is offline Reply With Quote Quote
Old 10-02-2008   #10
Re: GP Idle Speed
Quote Originally Posted by D4nny8oy View Post
Thanks mate - I'll feed that back to the main dealer - it's booked in again on the 25th Feb for a week. They want to have a good look at it.
Previously it's only done it when I've been in fairly heavy stop-start traffic, but that theory was blown out of the water yesterday when I just nipped out and it started again after about 2 miles (and very light traffic!!)
Old 23-02-2008   #11
Question Re: GP Idle Speed
Hi AJ, I am having exactly the same problems with my wifes GP 8valve 1.2 Active on a 56 plate.
Have you any further news or has the problem not reappeared?
Am thinking of taking it in to the main dealer to get checked over.
What kind of cost could I expect??
Richard Senior is offline Reply With Quote Quote
Old 23-02-2008   #12
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: GP Idle Speed
Quote Originally Posted by Richard Senior View Post
None.....its under warranty.
Old 24-02-2008   #13
Re: GP Idle Speed
The problem crops up every now and again - It first happened after about 1 month (500 miles) then nothing until early Dec 07 (8000 miles) - it's happened 4 times since Dec 07, during which time it's also had it's first 12 month service. I'm starting to get concerned because of the increased frequency of the problem and the dealer not being able to identify the cause. If they don't rectify it this time, then I'm sorry to say that I'll be changing car before the warranty runs out.
Get it into the main dealer ASAP mate, while it's still under warranty - NO COST TO YOU + THEY SHOULD SUPPLY A COURTESY CAR.
I hope they can sort it out because the GP's a nice little car.
Old 24-02-2008   #14
Re: GP Idle Speed
Richard,
Good luck at the main dealer - let me know how you get on?
Remember - insist on a courtesy car because they have got my car scheduled for a week, as they want to have a good look at it.
Old 18-06-2008   #15
Re: GP Idle Speed
I can confirm that I have now lost all faith in Fiat UK
My car has been at the main dealer since February 25th 2008 (yes Feb 25th!!) with the idle speed problem.
Although the AA were called out in the first instance and confirmed that the car was cutting out at idle speed, but no error was showing on the ECU. At this point I took the car back to a dealer in Mansfield, who re-set the ECU + did a new download - this cured the vehicle for about 8 months. In December 2007 it started doing it again, but it re-sets itself after a day or so. I played by the rules, phoned a closer dealer in Nottingham and reported the faul, but by the time they could see the vehicle it had re-set itself (in hindsight I should have taken it straight down to them, but I wouldn't have got a courtesy car)
It has been fully serviced by the main dealer according to their schedule, they said that after the first full service in Feb it would perhaps clear the fault - NOT A CHANCE - IT STARTED AGAIN ABOUT TWO DAYS AFTER THE SERVICE, but guess what, no errors were showing in the ECU.
The Fiat main dealer have road tested the vehicle a few times, hooked it upto the computer (No Faults Showing) and are now saying they can't find any fault with the vehicle and it is therefore with regret that Fiat UK are unable to assist me on this occasion
I am currently saying that I'm not happy at being fobbed off, when the fault was recorded and confirmed by the AA patrol and that Fiat UK should honour the warranty and either replace the ECU + associated sensors etc (the AA patrol suggested it could be a faulty ECU or sensor) or swap the car through their dealer network
I have never experienced customer service like this - I doubt if they would try and pass off this kind of service to your average German consumer
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
(G) Idle speed adjustment symonh2000 Cinquecento / Seicento 9 29-12-2007 15:49
(T) five speed conversion Icsunonove X1/9 2 03-07-2007 08:17
(G) Idle Speed PhilMcK Ulysse 3 12-12-2005 09:33
(T) Cinq Idle Speed adjustment namb Cinquecento / Seicento 4 06-10-2004 13:58
