It's pretty simple to do, you will just need a T piece on the inlet pipe then a vac pipe coming from that. Route it into the dash somewhere and mount the gaugae where you want it. I'd probably have it mounted to the right of the drivers side next to the small window. But mounting position is personal preference.
It's not difficult at all, just exactly the same as an other turbo car, you will need to measure the diameter of the inlet in order to find the right size T piece. I have some more info on this if you want to pm me.
Hope this helps
