hiya mate. if you put the figures into the letstorquebhp calculator it comes out as around 7.6 seconds iirc when you have it remapped to 170bhp. HTH... no idea if this is correct though, it's only supposed to be a rough guide.
Anybody with a remapped 1.9, have you tested your 0-60 time since you have had it remapped? Just curious to see what it is now?
If you've had your car re-mapped to 170bhp it should blow past almost everything on the road in 2nd-4th gear. The standing start will always be a horrible "brick wall in front of you" but once you hit 2000+rpm the turbo will come on strong..... You will also see nearly 48mpg (depending on who supplied the re-map):devil: .
around 7 secs mines does, depending on what kind of start u can get.!
also the gp is too light at the front to really keep the power down on the wheels to acheive 7 secs.
Too light at the front?! It has a heavy diesel lump in it, surely it should have more traction than a petrol equivalent with this extra weight.
What about cars like the Citroen Saxo that weigh 300kg less and manage sub 7 second 0-60's no problem at all, with a few mods.
The saxos have good power to weight ratios.
135bhp per tonne iirc.
Yeah and crap safety ratings .
And the fact that the GP Sporting is hard to get a good 0-60 time is all to do with the gearing not traction. Its geared to provide brilliant all around drivability and not for 0-60 sprints .
Yeah exactly . Last time I did 0-60 was a few months back at the lights against a Saxo VTR / VTS can't remember which one. I got in front though by a healthy gap not bad for a 1.4 16v mk2b Sporting . He didn't look too happy must have thought I had a 1.2 lol .
Agreed...My point was that the weight of the front won't be an issue...I certainly wasn't promoting the Paxo as being a good motor, just used it's lightweight build as an example!!!Yeah and crap safety ratings .
Question to Puntokris, who remapped your motor mate? Impressive figures!!!!!
