Old 07-05-2009   #46
Re: Flat Spot
Quote Originally Posted by Mattyk View Post
just clean it out yourself, its pisse easy if you have a socket set and an hour or so, read the guide in the guides section and look at the pictures
think i might do, however iv read something about a smaller gasket which acts as a restrictor, as without this it will always need cleaning.
Robert1031 is offline Reply With Quote Quote
Old 09-05-2009   #47
Re: Flat Spot
since my last post i have followed the guide on cleaning out my EGR valve, although loads of **** came out it has only improved my performance ever so slightly. However there is no power until 2300 rpm its horrible to drive. this makes me think that the mechanical side to the egr valve is okay and that the electrical side is faulty. However when i went to see my fiat dealer he said that they arent able to do anything with it unless the ecu light is on and its not even though they know about the problem with the egr valves. How do i get them to fix it? and also is this deffinatly the problem?
Old 09-05-2009   #48
Trader Rating: 2
Re: Flat Spot
Could be wrong but I think there is a known problem which Fiat are aware of.
The dealer needs to check the injectors (I think there may be a dodgy batch) and then apply a new map which apparently cures the problem.
How old is the car, seems to be affecting newer models
IainG GPS is offline Reply With Quote Quote
Old 10-05-2009   #49
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: Flat Spot
Quote Originally Posted by Robert1031 View Post
If its new (still under warranty) and bought from them say the performance is no where near satisfactory for the spec of the car and is borderline dangerous and unfit for purpose. Failing that try another dealer or threaten rejection (you'll have more clout if its bought on finance).
ChrisUK is offline Reply With Quote Quote
Old 10-05-2009   #50
Re: Flat Spot
Quote Originally Posted by IainG GPS View Post
its an 2007 on an 07 plate, i bought it privatly but is still under warrenty. However the car has been remapped by red dot so im guessing that if they apply the new map i will loose the old one.
I still dont understand how it was working perfectly until a few weeks back.
Old 10-05-2009   #51
Trader Rating: 2
Re: Flat Spot
You would lose the redot map but have a word with them, you never know
Old 14-05-2009   #52
Re: Flat Spot
Quote Originally Posted by new2fiat View Post
Good news - the flat spot has been fixed!!!
The dealers knew about the EGR problem already without me having to say anything, but after some further investigation (and thankfully having been able to feel it for themselves on a test drive ) they did this:
"Basically we have fitted a restriction to the egr system, which reduces the cross sectional area available for the exhaust gas to pass through into the inlet manifold. This restriction acts like a venturi and speeds up the gas passing through it, so making it mix better with the inlet air and also clean the egr valve itself. It does not reduce the exhaust gas passing through it as we have checked this using airflow meter readings. This is available for most egr systems on Fiat 1.9 and 2.4 diesel engines.
Service news 10.21.08 includes a test procedure to follow before fitting the restriction."
Hope this makes sense to anyone with a similar problem - and that it helps you too! It's another niggly problem with the car fixed
thanks alot for this mine is at the dealer now trying to sorted it i had engine managment light on and asr dissconected itself had mega loss of power and had that flat spot aswell all the time when driving the dealer said the lights was because of a loose earth wire and they they though the power loss was because the fuse box was damp and they are now replaceing that at a cost of 300 pound to them stupid people this is the 4th time it has been back for the same fault
scottsworth is offline Reply With Quote Quote
Old 12-08-2009   #53
White Grande Sporting
Mayatt's Avatar
Mayatt has donated!
Re: Flat Spot
having the same problem too on an 08 car might be the excuse i need to go and see reddot
click sig for profile
Mayatt is offline Reply With Quote Quote
Old 12-08-2009   #54
Banned
punto_matt's Avatar
punto_matt has donated!
Western Samoa
Re: Flat Spot
Come down on sunday
punto_matt is offline Reply With Quote Quote
Old 12-08-2009   #55
Stuff Your Own Title
beany_bot has donated!
Re: Flat Spot
Mine had this flat spot. got it mapped at red dot and its gone away. simples
1.9 Multijet Sporting +Leather +Cruise +Climate
177.6Bhp 340Nm Torque - Cheesiest Sig Competition 2009 Powered By TBP
beany_bot is offline Reply With Quote Quote
Old 12-08-2009   #56
Mayatt's Avatar
Mayatt has donated!
Re: Flat Spot
cars in bodyshop and would be up lol
(T) flat spot when hot Bushboy Cinquecento / Seicento 17 13-03-2010 15:50
(T) Flat spot in 1st: ECU question... ronnieronson Cinquecento / Seicento 23 02-06-2007 09:20
(T) BIG flat spot! chazzer Cinquecento / Seicento 53 25-04-2007 22:02
(T) Strange Flat Spot? EvilJaxx Cinquecento / Seicento 17 06-05-2005 12:44
(G) Carb flat spot Uno 60S (Solex carb) Brymak Uno 3 29-11-2004 02:06
