FIAT Auto Specialist Team
Old 14-08-2008   #31
Jap Slut
puntokris's Avatar
puntokris has donated!
Re: Flat Spot
Quote Originally Posted by Shropshire_lad View Post
How's your turbo bearing up Kris?
Its lasting out at the moment, I gave it a check over last night and seems to be putting out nice amounts of oil and smoke. I also spent last night putting bits back to standard ready to go into fiat to get it replaced.
Its definitely on its way out but I think its lasted well for a faulty unit, the cars done nearly 35k.
I've been driving it very steady for the last month or so because I don't want the dreaded white smoke and collapsed bearings before it goes back into the garage
C:\Users\User\Pictures\Type-r
puntokris is offline Reply With Quote Quote
Old 14-08-2008   #32
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Flat Spot
Quote Originally Posted by puntokris View Post
Puntokris comments required below
https://www.fiatforum.com/grande-pun...re-mapped.html
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 14-08-2008   #33
Re: Flat Spot
Booked mine in for its second year (major) service, i mentioned the flat spot (aswell as many other things i would like sorting) to the service clerk and she seemed to know what i meant, so hopefully it will be sorted. Its not a mojor problem, only happens once a week for me, at first i shat myself because i thought it was my clutch slipping, that wouldn't have been particuarly fun.
snownrock is offline Reply With Quote Quote
Old 06-05-2009   #34
Re: Flat Spot
Quote Originally Posted by new2fiat View Post
Good news - the flat spot has been fixed!!!
The dealers knew about the EGR problem already without me having to say anything, but after some further investigation (and thankfully having been able to feel it for themselves on a test drive ) they did this:
"Basically we have fitted a restriction to the egr system, which reduces the cross sectional area available for the exhaust gas to pass through into the inlet manifold. This restriction acts like a venturi and speeds up the gas passing through it, so making it mix better with the inlet air and also clean the egr valve itself. It does not reduce the exhaust gas passing through it as we have checked this using airflow meter readings. This is available for most egr systems on Fiat 1.9 and 2.4 diesel engines.
Service news 10.21.08 includes a test procedure to follow before fitting the restriction."
Hope this makes sense to anyone with a similar problem - and that it helps you too! It's another niggly problem with the car fixed
can you explain exactly what you had done, i cant seem to understand?
Robert1031 is offline Reply With Quote Quote
Old 07-05-2009   #35
Stuff Your Own Title
beany_bot has donated!
Re: Flat Spot
I had this exact same problem but it went away after i got my map.
1.9 Multijet Sporting +Leather +Cruise +Climate
177.6Bhp 340Nm Torque - Cheesiest Sig Competition 2009 Powered By TBP
beany_bot is offline Reply With Quote Quote
Old 07-05-2009   #36
Re: Flat Spot
Quote Originally Posted by Robert1031 View Post
Sorry, I wish I could, but I don't understand the technical details either. This is what the Fiat technician told me, so hopefully if you take it to a dealer, they will be able to understand.
new2fiat is offline Reply With Quote Quote
Old 07-05-2009   #37
Re: Flat Spot
So i take it its fixed now then?
Old 07-05-2009   #38
Re: Flat Spot
Yep
Old 07-05-2009   #39
Re: Flat Spot
so if i got to my fiat dealer and quote the service test thing you mentioned they should understand and if it needs it they will restrict it or something?
Old 07-05-2009   #40
Re: Flat Spot
I have the ‘flat spot’ problem with my car, now after reading the threads on here I realise that the problem could be because of the EGR valve getting crap on it. If I was to take my car into fiat and get them to do it under 3rd year warranty and clean the EGR valve and put a restrictor gasket on it, would they be prepared to do this or would they act ‘clueless’ towards the fault.
Also my car is mapped so would this effect my remap on the car and will fiat use the map as an excuse to not to the EGR valve under warranty?
Old 07-05-2009   #41
Banned
punto_matt's Avatar
punto_matt has donated!
Western Samoa
Re: Flat Spot
Jesus christ you dont need to post it in every thread
punto_matt is offline Reply With Quote Quote
Old 07-05-2009   #42
Re: Flat Spot
Quote Originally Posted by punto_matt View Post
i do its pissing me off and i want it sorted asap.
Old 07-05-2009   #43
Banned
punto_matt's Avatar
Western Samoa
Re: Flat Spot
Well go to your dealer and ask them then. Bumping every thread on it isnt going to get it answered any faster your just filling this part of the forum with the same bloody thing.
Old 07-05-2009   #44
Re: Flat Spot
just clean it out yourself, its pisse easy if you have a socket set and an hour or so, read the guide in the guides section and look at the pictures
www.weekendracer.co.uk Trackday Club
185.9bhp / 316 ft/lbs
Mattyk is offline Reply With Quote Quote
Old 07-05-2009   #45
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: Flat Spot
Yep
How's the old beast running now? I still miss it lol
ChrisUK is offline Reply With Quote Quote
(T) flat spot when hot Bushboy Cinquecento / Seicento 17 13-03-2010 15:50
(T) Flat spot in 1st: ECU question... ronnieronson Cinquecento / Seicento 23 02-06-2007 09:20
(T) BIG flat spot! chazzer Cinquecento / Seicento 53 25-04-2007 22:02
(T) Strange Flat Spot? EvilJaxx Cinquecento / Seicento 17 06-05-2005 12:44
(G) Carb flat spot Uno 60S (Solex carb) Brymak Uno 3 29-11-2004 02:06
