Old 09-06-2008   #16
Australia
Re: Flat Spot
EGR valve? Pardon my ignorance, but what is it?
Dirty Waltzer is offline Reply With Quote Quote
Old 09-06-2008   #17
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Flat Spot
exhaust gas recirculation valve, quite common fault on diesels & can give many different symptons.
Old 09-06-2008   #18
Australia
Re: Flat Spot
Quote Quote:
Thanks for that. Will look into it.
Old 09-06-2008   #19
Re: Flat Spot
EGR valve may need cleaning not unheard of on diesels! 2 hour job roughly
v12ock is offline Reply With Quote Quote
Old 14-06-2008   #20
Re: Flat Spot
I'll mention the EGR valve to the dealers on Monday when I take the car in - thanks for that advice.
I'm not keen on re-maps - although I know the benefits are potentially huge, there's the complication of insurance and warranty....
new2fiat is offline Reply With Quote Quote
Old 24-06-2008   #21
Re: Flat Spot
Good news - the flat spot has been fixed!!!
The dealers knew about the EGR problem already without me having to say anything, but after some further investigation (and thankfully having been able to feel it for themselves on a test drive ) they did this:
"Basically we have fitted a restriction to the egr system, which reduces the cross sectional area available for the exhaust gas to pass through into the inlet manifold. This restriction acts like a venturi and speeds up the gas passing through it, so making it mix better with the inlet air and also clean the egr valve itself. It does not reduce the exhaust gas passing through it as we have checked this using airflow meter readings. This is available for most egr systems on Fiat 1.9 and 2.4 diesel engines.
Service news 10.21.08 includes a test procedure to follow before fitting the restriction."
Hope this makes sense to anyone with a similar problem - and that it helps you too! It's another niggly problem with the car fixed
Thanks kip02 thanked for this post
Old 10-08-2008   #22
Australia
Re: Flat Spot
Alright I have a service coming up next couple of weeks and will try for the fourth time to get this flat spot issue sorted.
new2fiat thankyou for your post. I will quote
Quote Quote:
when I speak to the service manager. Just a question however. How is it going for you now? any sign of the flat spot returning?
Old 10-08-2008   #23
Re: Flat Spot
Yep, it's still all 100% fine now - absolutely no sign of the flat spot, even when using supermarket diesel (which always made it worse, for some reason).
Good luck!
Old 10-08-2008   #24
Re: Flat Spot
I fitted this to my Stilo and its made a world of difference, idle speed is smoother, and quieter, and pick up from low revs is definately smoother. I didnt have a flat spot anywhere near as bas as new2fiat but its definately improved my vehicle.
"Every day, in every way, I get better and better"
NumanR is offline Reply With Quote Quote
Old 10-08-2008   #25
Re: Flat Spot
I was just about to post about this but seen this post.
I have the same problem mines a April 06 and stutters when cold, also has great trouble starting sometimes.
Mine has had a EGR valve replaced about 3 months ago due to total loss of power.
I can go armed with this when i go to the dealers next week. Cheers
kip02 is offline Reply With Quote Quote
Old 11-08-2008   #26
Re: Flat Spot
mine also use to have problems when starting and then initially replace the lambda/o2 sensor and that didnt really cure the matter so they replaced the inlet manifold and it seems much better now i am also getting flat spot, not quite that bad only every now and then! Will have to take the car in to getthe EGR looked at.
1.8Stilo is offline Reply With Quote Quote
Old 11-08-2008   #27
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Flat Spot
Quote Originally Posted by 1.8Stilo View Post
Before or after 24th?
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 11-08-2008   #28
Re: Flat Spot
Quote Originally Posted by Ffoxy View Post
before, this wednesday..... so we'll see what happens! they best not rinse my diesel this time!
Old 14-08-2008   #29
Jap Slut
puntokris's Avatar
puntokris has donated!
Re: Flat Spot
I had a new egr valve on mine a while back, there was no performance issue just soot being sprayed from it. Also check maf sensor and exhaust leaks if you are experiencing a loss of power (especially on and aroudn the turbo itself). Could be an early warning sign of your turbo being on its way out.
C:\Users\User\Pictures\Type-r
puntokris is offline Reply With Quote Quote
Old 14-08-2008   #30
Shropshire_lad has donated!
Re: Flat Spot
Quote Originally Posted by puntokris View Post
How's your turbo bearing up Kris?
Shropshire_lad is offline Reply With Quote Quote
(T) flat spot when hot Bushboy Cinquecento / Seicento 17 13-03-2010 15:50
(T) Flat spot in 1st: ECU question... ronnieronson Cinquecento / Seicento 23 02-06-2007 09:20
(T) BIG flat spot! chazzer Cinquecento / Seicento 53 25-04-2007 22:02
(T) Strange Flat Spot? EvilJaxx Cinquecento / Seicento 17 06-05-2005 12:44
(G) Carb flat spot Uno 60S (Solex carb) Brymak Uno 3 29-11-2004 02:06
