I've hooked up a custom sub to the standard radio (incl. Blue&Me) by using the same connector the factory fitted sub is hooked up with. This is how I did it:
In the boot on the right, you can unscrew the sidepanel on the top. After that, you can create some space between the sidepanel and the car body. You will find the sub connector behind it. This is what the connector looks like:
The pins of this connector are as follows:
Make sure the amp you connect supports high/speaker level inputs, preferrably with adjustable input sensitivity. Also be very careful when cutting the continuous 12V+ wire! Make sure the car is switched off when cutting wires and connecting them again and avoid shorting this wire to the car's body. The continuous 12V wire should be able to provide about 12V/15A which equals ~180W consumed power. There's also an extra (switched) 12V wire available in the boot on the left sidepanel (for the external 12V in boot option) if needed. This is how it looks like in my GP:
The amplifier is a Kenwood KAC-6203. The sub is just something I had lying around and has 2x8" woofers. It's nothing fancy, but I'm satisfied with the result.
Kind regards,
Michel
Code:
1 3 4 5 7
|0 0 0 | 0 0|
|0 +---+ 0 0|
2 6 8
- Remote 12V+; switched (grey)
- Continuous 12V+ (red/white)
- Shield (-) (black)
- not connected
- Speaker right - (blue/black)
- Speaker right + (blue/red)
- Speaker left - (orange/black)
- Speaker left + (red/grey)
Kind regards,
Michel
