hey
i am trying to figure out how to fit a sub does the standard head unit support
an amp and a sub (the right connections?).
and another question.
how the hell do you remove the head unit i cant seem to get it out
dont go for 12" always the 10"
you will get a better respeonse from the sub speaker and therefore better sound quality
well i have heard alot of sound systems with 12" up to 18"
and i just thought when i heard a 10" it just sounded to much clearer with less rumble noise with more of a punch i mean its a personal preference but that what im going for
check the pics of the subs im getting
it has all the speks to
go to:
styling
post is called pics of the subs YEAH!
:slayer:
So the box volume, the sub used, the power it was seeing and the quality of the installation had nothing to do with it?
but 10" are the way
in response to the original question, i have a sub along with the standard head unit, QUOTE]
So it was easy enough to fit to the standard headunit yes? Because I got the same feelings on changing the headunit as you minnnt, It will end up looking messy.
yeah i totally get you
but...
again it also depends what music you like
for me i like rock music so i need need a better response from a sub
thats why i say ten inch
but say for d&b or grime you would want a 12" or bigger which is fine all i was saying was that you will always get a better response from te speaker if its 10"
but..
you can have a 10" that is obsecenly loud.
you can get a 4 channel amp, two subs and you bridge two channels together for each sub
therefore getting almost double the power but again i need a quicker response from the speaker so 10" for me
at the end of the day its just personel preference!
but my opinion is that 10" are the way
and i respect your opinion:worship: :slayer:
