Comment
Guide Tools
Fitting front fog lights
T14086
28-12-2006
<b>A few points to note!</b><br />
<br />
A relay <u>must</u> be fitted in the circuit.<u>DO NOT</u> try and wire fog lights directly to any other circuit,do not go near the body computer or try and utilise the original menu/rear fog multifunction switchbank as doing so will cause damage to your
Old 27-10-2011   #30
Re: Fitting front fog lights
Can someone please tell me where i can get all of the parts to do this please, i have been looking at doing this for a while now but i cant seem to find everything that i need and if what i am looking at buying is the right thing that i need.
Any help much appreciated.
Daz
dazzastocky is offline Reply With Quote Quote
Old 27-10-2011   #31
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Everything you need can be gotten from ebay, certainly that's where I got it all from, if you're not keen on ebay - the fogs can be bought direct from Fiat and the relay/fuseholders/switch/wire should all be available at your local auto electrical place, possibly even from electronics places like Maplin.
Eklipze3k is offline Reply With Quote Quote
Old 27-10-2011   #32
thanks for the quick reply
i am a keen ebayer but i just wasnt sure if i was looking at the right stuff or not so wasnt going to buy until i knew i had the right stuff.
have you got any links to the stuff you bought and i can have a look and see if im looking at the right stuff or not.
cheers
daz
Old 27-10-2011   #33
No strings on me
Eklipze3k's Avatar
Quote Originally Posted by dazzastocky View Post
cheers
daz
It was a while ago so I don't have the link anymore but - when getting the lights themselves, avoid the cheap ones from Bulgaria as they are terrible quality. The relay was easy enough to find - just make sure the picture on the top matches up with the one in the guides, blade type fuse holders are standard fare, as are the blade fuses and the 18gauge wire. Post up links to anything you're not sure about and we'll soon tell you if it's right or wrong
Old 27-10-2011   #34
do you know of any stores that might stock all of what i need as i may just go out tomorrow and get it all save waiting!!
cheers daz
Old 02-11-2011   #35
Its Not Just A Grande...
fatti1477 has donated!
Anyone know the exact size of the Spade Connectors for the back of the Fog Lamps?
Grande Punto 1.2 Active
Ice Hockey
fatti1477 is offline Reply With Quote Quote
Old 24-04-2012   #36
Chile
Hi there! I loved this guide. It was one of my first mods (I'm going to modify mi rally fog lights now though... its gonna look awesome! wait for the thread )
I have a question though... can I fit a led to the dash where the original fog lights indicator is?
my idea is to fit a green led with a resistor where the original used to go but i don't know if its going to fit in there or not.
Has anyone done this? it would look pretty stock
GP ACTIVE 1.4 8v 77hp (hell's ponys)
etche is offline Reply With Quote Quote
Old 24-04-2012   #37
Moderator
Andy Monty's Avatar
Andy Monty has donated!
if you have the balls to take your binical apart i suppose it could be done just take care not to knacker the speedo cluster up....
not that i would ever admit to putting a short on my ka and blowing a PCB track
Massive gash
Just a little touch up
Old 24-04-2012   #38
Chile
But I don't intend to use the original led, i want to fit an external one but I don't know if it will fit between the pcb and the "black thing with the numbers printed on". Should I use a 5mm green led or maybe a SMD led (I think these are too small though and won't iluminate the icon completely).
Where can i find a opened dash to see how all fits in there?
Old 25-04-2012   #39
Chile
I think I'm gonna try to do this:
http://procustomizers.com/showthread...-wire-SMD-LEDs
And install it behind the fog light indicator in the dash
You can also buy them here:
http://www.oznium.com/prewired-surface-mount-led
as you can see they are very thin:
Here's a video on how to diy:
http://www.youtube.com/watch?v=oKxY0...yer_embedded#!
and the leds:
http://www.ebay.com/itm/150786811714...ht_3343wt_1037
If I insulate well the back of the led, then i shouldn't have any problems putting it in front of the original fog light indicator led....right? but does it fit between the original led and the black thingy?
Old 29-01-2013   #40
Philious
philious has donated!
So has anyone tried using a stoke fog light switch to operate the fogs???
philious is offline Reply With Quote Quote
Old 29-01-2013   #41
No strings on me
Eklipze3k's Avatar
If by 'stoke' you mean 'stock' then no, because that switch sends a signal to the body computer rather being a simple on/off switch.
Old 27-09-2013   #42
Greece
Hello to all members of fiat forum
i need some help
i went to my local electric garage to put the fog lights in my GP
i bought the fog lights and one universal switch
he said to me that is not nessesary to put a relay.
so he didnt put in the circuit relay and he put the switch down from the ODB port at the cap
my problem is that i forget 2 times the fog lights on and i lost the battery !!!what can i do to close the fog lights when i close the engine?can someone draw me the circuit that i need?
sorry for my bad Einglish
Alkis7 is offline Reply With Quote Quote
Old 27-11-2013   #43
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by Alkis7 View Post
Tell him he is wrong then
Old 06-02-2014   #44
Hi everyone,
I know I am late to the party but i recently got a GP and I have came to realise I really like them with fog lights.
I am thinking about buying some and fitting them with some help for my mate. The main question I have is, is it possible to wire it so the fuse is the one in the fuse box? Meaning the fogs are wired to the fuse box and the fuse is in the standard front fog light position.
If not there in the sequence do you but the fuse? I don't understand that part of the install. I have seen a relay on eBay with the fust built into the top, is this what every replay is like?
Thanks for any help given
jackgoughblah is offline Reply With Quote Quote
Comment
Guide Tools
(G) fitting fog lights into a punto made without them evol1 Punto (Mk2/2b) 4 25-04-2006 10:18
(S) Front Fog lights Sonic74205 Bravo / Brava 25 26-03-2006 18:39
(T) i thought fog lights only worked on half beam?? beau Punto (Mk2/2b) 7 20-03-2006 17:55
(S) Front fog lights on Uno 45 uno_man Uno 2 29-11-2002 00:53
