Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fuse Box Removal<!-- google_ad_section_end -->
Fuse Box Removal
Damp here cause lots of electrical gremlins
Published by john7
08-01-2018
Difficulty Level: 1
User Rated:
Difficulty Level: 1
Engine Compartment Fuse Box Removal
Background
My daughter's 2007 1.2 Active had door open warning light on all the time, and other warning lights on intermittently. Periodically the headlamps would come on themselves and also the feed to the starter was also not getting power. I suspect that possibly the fuel pump wasn't getting power either, as the car refused to start with a tow.
Tools
Flat screwdriver, 10 and 13 mm sockets and ideally a 10 mm ring spanner.
Removal of Battery
Use 13 mm socket to undo the bolt holding the battery strap. Release the battery negative terminal lever, and move aside. Remove the plastic cover on positive battery terminal, then use 10 mm spanner or socket to undo it, and move it aside. Remove battery.
Thanks Simlrs thanked for this post
Contents
<< <    Next Page: Removal of fuse Box (Page 1 of 3)    >  >>
Comment
Search this Guide:
(T) F30 15amp fuse melted in fuse box above battery. dtimmins1985 Stilo 4 13-12-2017 13:44
Punto Evo Help! Unknown fuse box type: fuse diagram needed Punto2009TF Newbie Central 2 25-03-2017 18:11
(T) Fuse box removal TimKUK Grande Punto 5 08-01-2015 22:56
(T) Fuse Box Removal Moonbutt Grande Punto 0 07-05-2010 06:23
(T) Spare Fuse Position in Fuse Box? JonActiveSport Grande Punto 4 31-12-2009 08:40
