im Axle Specialists
Comment
Guide Tools
<!-- google_ad_section_start -->Fuse Box Removal<!-- google_ad_section_end -->
Fuse Box Removal
Damp here cause lots of electrical gremlins
Published by john7
08-01-2018
Difficulty Level: 1
User Rated:
Difficulty Level: 1
Possible Cause
If the box is wet inside, take it indoors and let it dry overnight. In my case the fuse box was dry but the largest connector was full of water. I dried this out with a hairdryer. I then put everything back together complete with a freshly charged battery. Car started with no warning lights showing.
The issue remaining is how the water got in. I suspect it was because the piece of rubber in the right hand corner of the engine bay was out of place.
This is held in place by a single plastic stud. The hole that the stud passes through was torn and the stud was lost. I have a Punto Evo myself, and I noticed that the engine fuse box on it is completely different. Maybe others have had this same issue.
Thanks Simlrs thanked for this post
Contents
<<  <    (Page 3 of 3)    > >>
Comment
Guide Tools
(T) F30 15amp fuse melted in fuse box above battery. dtimmins1985 Stilo 4 13-12-2017 14:44
Punto Evo Help! Unknown fuse box type: fuse diagram needed Punto2009TF Newbie Central 2 25-03-2017 19:11
(T) Fuse box removal TimKUK Grande Punto 5 08-01-2015 23:56
(T) Fuse Box Removal Moonbutt Grande Punto 0 07-05-2010 07:23
(T) Spare Fuse Position in Fuse Box? JonActiveSport Grande Punto 4 31-12-2009 09:40
