Comment
Guide Tools
<!-- google_ad_section_start -->Fuse Box Removal<!-- google_ad_section_end -->
Fuse Box Removal
Damp here cause lots of electrical gremlins
Published by john7
08-01-2018
Difficulty Level: 1
User Rated:
Difficulty Level: 1
Removal of fuse Box
Use flat bladed screwdriver to open lid of fuse box. Use 10 mm socket to loosen nut inside fuse box. Remove nut then you can lift off the heavy red power lead. The fuse box is mounted in a metal cradle/bracket. Prise the front edge of cradle to release a tiny plastic square that stops the fuse box from rotating. You can then rotate the box through 90 degrees. You can then see three big connectors on the bottom of the fuse box. Remove these and you can lift the fuse box out.
Thanks Simlrs thanked for this post
Contents
<<  <    Next Page: Possible Cause (Page 2 of 3)    >  >>
Comment
Guide Tools
(T) F30 15amp fuse melted in fuse box above battery. dtimmins1985 Stilo 4 13-12-2017 14:44
Punto Evo Help! Unknown fuse box type: fuse diagram needed Punto2009TF Newbie Central 2 25-03-2017 19:11
(T) Fuse box removal TimKUK Grande Punto 5 08-01-2015 23:56
(T) Fuse Box Removal Moonbutt Grande Punto 0 07-05-2010 07:23
(T) Spare Fuse Position in Fuse Box? JonActiveSport Grande Punto 4 31-12-2009 09:40
