FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Seat belt buzzer\light disable (reversible process)<!-- google_ad_section_end -->
Published by mankam
23-11-2017
Difficulty Level: 1
User Rated:Unrated
Seat Belt are very important in driving. Many accidents happen every single day and proper use of safety restraints have saved many lives.
Sometimes the seat belt holder, sensor thingy, doesn't always recognizes the seat-belt is plugged in, and the buzzer coming.
This is the easy and reversible way to disable it.
The process is similar to other cars and is done separately in the driver and front passenger seat.
You will need:
A small flat screwdrive
a tape
10cm cable
First locate the plug-connector cover under front side to the seat.
use a small flat screwdriver to remove the 2 plug
now as you see in photo there is a 2 pin connector,
remove the insulation from the cables without cutting them.
Remove the insulation from another cable and wrap it around the two cables.
This will close the circuit and the car recognizes that the seat belt is in its position.
Insulate the 2 cables with tape and plug the connector back.
That's it, enjoy the result's!
Comment
Search this Guide:
(T) Seat belt warning buzzer Peter Rawlings Panda (2012+) 21 10-05-2016 11:37
(T) Disable airbag warning light for seat replacement? jnoiles 500 4 03-08-2009 01:48
(G) Seat Belt Warning light and buzzer coming on!! slimgimli 500 16 22-06-2008 18:23
(T) Seat belt light Billzer Marea 3 10-11-2004 17:36
