Comment
Guide Tools
<!-- google_ad_section_start -->grande punto dash bolts locations removal<!-- google_ad_section_end -->
Published by flisko
15-05-2017
Difficulty Level: 3
User Rated:Unrated
grande punto dash dashboard bolts locations removal
First disconnect battery
Thanks ben thanked for this post
Contents
<< <    Next Page: Mandatory tools (Page 1 of 3)    >  >>
Old 15-05-2017   #1
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: grande punto dash bolts locations removal
Quote Originally Posted by flisko View Post
[BREAK=Mandatory tools]
Mandatory tools
torx keys
opposite torx for lower steering column bolt
allen keys
flat and + screwdriver
socket wrench size 10, 13, long extension for steering column bolts
for bolt above city switch its easier to use torx or else its gonna take quite longer to remove it pic 171649
Attachment 180454
[BREAK=Bolts locations]
remove
  • both front doors
  • body ecu
  • whole steering column
  • fog lights switch
  • plastic below windshield- top of dash
  • radio- without proper tools just insert 4 small allen keys inside the 4 holes and pry it out with flat screwdriver- pic below
  • city switch
  • speedo clock
  • disconnect all cables or cut them
After all the bolts above are removed dash should pull out, if its not going out with ease then some bolt is still holding it
Attachment 180455
Attachment 180457
Attachment 180459
Attachment 180460
Attachment 180462
Attachment 180463
Attachment 180465
Attachment 180466
Attachment 180467
Attachment 180468
Attachment 180469
Attachment 180470
Attachment 180471
The GP uses RIBE (Polydrive in North America) type fasteners NOT Torx. While you can possibly manage to use a Torx driver it can damage the fastener and driver. Best to get the correct tool. I use these
https://www.machinemart.co.uk/p/clar...-set-22-piece/
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 15-05-2017   #2
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Quote Originally Posted by g8rpi View Post
Robert G8RPI.
Ribe bolts only appear in the engine bay Robert. In the cabin, Torx is king. Never seen any ribe on the interior
Current Garage
Mine: 2013 VW Passat Sport BlueMotion Tech 2.0 TDI Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 15-05-2017   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by brickfoot View Post
OK, I'm going to have to stop responding to posts before I've had my first coffee of the day
Likes MrDerv liked this post
Comment
Guide Tools
(T) Grande Punto alloys and bolts Q. Puntopenny Grande Punto 5 21-04-2010 10:02
grande punto alloy wheel bolts stutheo Lets Talk FIAT 0 14-09-2009 20:01
