Comment
Guide Tools Search this Guide
Grande Punto Power Steering Column Replacement
Steering noise, vibration or judder & occasional loss of power steering
troy_paris
23-02-2014
<b><font size="5">Steering noise, vibration or judder &amp; occasional loss of power steering. Diagnosis from a dealer is that the power steering column needs replacing. Quoted 600 from the dealer to fix it. <img src="images/smilies/eek.gif" border="0" alt="" title="" class="inlineimg" /> Read on
Old 11-04-2017   #15
Re: Grande Punto Power Steering Column Replacement
I need to do one but it on the Evo. Would it be pretty much the same?
bell100 is offline Reply With Quote Quote
Old 02-03-2019   #16
I have just completed a PS motor and ECU change on a 2006 Grande Punto.
I just wanted to thank all who posted here for this invaluable thread.
I bought the said Punto about 6 weeks ago and was devastated when Fiat told me the horrible vibration it suddenly started making every time it turned right was down to faulty sensors in the steering column PS motor and it would all have to be replaced at a cost of 1400.....
After picking myself up off the floor I decided to see if I could find parts any cheaper which led me to this forum and specifically this post. I read and re-read the thread and decided to see if my (very) local fiat scrapyard might possibly have a replacement motor. A very helpful chap at DS motors in wickford Essex said "yes he had a motor and it would be 65. "
Long story shortened....after toing and froing to the local car spares shop for the tools I didn't have ( I am in no way a mechanic - actually a Mac operaor in the print trade and much more at home with computers). I got stuck in using the all in one lump method suggested by andyBM3's.
Once all the plastics are removed it is literally 5 bolts to undo.
2 that hold steering wheel and control stalks to steering column.
2 that hold the PS motor in place
1 that attaches steering column to steering rack.
I found it a bit fiddly getting the bolts back in that secure the PS motor
And the electrical clip with the yellow release latch foxed me for a while, you have to prize the top bit of the yellow button up with a flat head screwdriver and then squeeze the remaining yellow bit to release it.
I was also worried that a scrap PS motor would need calibrating in some way but it is working perfectly and feels so much better.
All in all it took me about 4 hours to do and I wouldn't have considered trying it without this post. So that is 1335 pounds saved thanks to you guys.
Likes Michael Dranfield liked this post
Colonel Bogey is offline Reply With Quote Quote
Old 03-03-2019   #17
Vatican City
Post Re: Grande Punto Power Steering Column Replacement
Good Guide, OK, but, why whole unit swap?
Most common problem is the sensor itself in Grande (in Punto2 was sensor + some relays).
https://www.google.com/search?tbm=is...t+punto+sensor
It can be replaced way more cheaper than entire, complete power steering unit.
Downside is the calibration procedure (tricky).
Last edited by GrandePunto PL; 03-03-2019 at 17:25. Reason: YOU CAN REPLACE SENSOR ONLY!
GrandePunto PL is offline Reply With Quote Quote
Old 04-03-2019   #18
Quote Originally Posted by GrandePunto PL View Post
The link you provided points to sensors that cost 100-150 and how do you know you got the right one? Then you have to strip the motor down and rebuild it. For us non-mechanics thats a daunting prospect. Then its got to be calibrated. Do you need a special tool for that?
Don't think andyBM3's method can be beaten for ease and economy.
I replaced my faulty PS motor with a scrap one for 65 and it is working perfectly and will hopefully continue to do so. I have also just received an offer of 25 from one of the reconditioning companies for my faulty motor.
So 40 to do a repair that Fiat wanted to charge me 1400 for. Just keeps getting better.
Old 18-04-2019   #19
This lost helped me too but fornmy case it was a bit different...
On my 2009 bravo tjet 150 the steering wheel is not the shown above one it is the one that you have to put the screwdriver straight up from the hole.
Now i did not know that so eager me poking around said holes for a good 2 hours...
Now after this i lost my **** grabbed my knife and literally cut the side of that goddam wheel... Than i seen what the takeoff method is and took me 2 minutes... But my new wheel i have refurbished needs differnt airbag so now im waiting for that....
I could bloody scream as i wanted to refurb the old wheel too and sell it. Cant do it now.
Murkovics is offline Reply With Quote Quote
Old 19-10-2019   #20
France
Hi all,
Thank you for the helpful instructions, my car now doesn't have PAS faults or graunching when turning left
My car is LHD but there was only one significant difference - the cable to the steering wheel is not long enough to stretch to the passenger side so I had to variously 1) lay it in the driver's footwell, 2) Hang it on the gearknob! and 3) perch it on the doorsill.
I had difficulties with both bolts for the lower column. The top bolt was bent so was difficult to get back in without cross-threading (and I didn't have a spare) and the bottom one's thread got mashed up on the fitting coming up through the floor while I tried to put it back in; it took some jiggling to get past it and screw into the captive thread.
I also had to employ some levers, penetrant oil and a mallet to get the lower column off the back of the motor unit, it was very stuck on. My car is from 2005 so if the PAS unit is original then this could be why it's so stuck. I also had to use a mallet to get it back on.
But once it was all back together and I turned the ignition on with some trepidation I was very pleased to find that no errors came up. I was even more pleased to hear that the graunching had gone! This means it wasn't the strut top bearing after all: https://www.fiatforum.com/grande-pun...-grinding.html
For info, I bought my replacement reconditioned unit here: https://www.ebay.co.uk/itm/392289880364 You have to return your old wheel to them. They can exchange emails in English and they said there is no time limit for returning your old one, but I expect they'll get pushy if it takes more than a month. Delivery from Italy to France took only Monday to Thursday; I placed the order on the Saturday prior.
Thanks again
madbilly is offline Reply With Quote Quote
Old 29-12-2019   #21
damted has donated!
Netherlands
Indeed this procedure can be done also, but proper installation can be tricky.
For calibration you might need MES software or other tools.
I did it myself because I also got a very detailed installation guide together with the steering angle sensor.
Life time warranty on the whole unit without having to struggle with difficult installation of the sensor can be a good reason to spend a little bit more.
damted is offline Reply With Quote Quote
Comment
Search this Guide:
(T) grande punto steering column fault teepee Grande Punto 48 16-02-2012 18:30
(T) Punto electrical steering column/power steering fairview7 Punto (Mk2/2b) 3 19-02-2011 19:33
(T) GRANDE PUNTO 06 needs new steering column - but does it need calibrating by Fiat deal lynniep Grande Punto 21 10-01-2011 21:26
Punto (Mk2/2b) punto 188 power steering column quick sale on ebay rybach Auction Watch 0 11-04-2010 11:44
