Comment
Guide Tools
<!-- google_ad_section_start -->Boot locking mechanism replacement / Repair<!-- google_ad_section_end -->
Published by Andy Monty
12-12-2013
Difficulty Level: 2
User Rated:
Difficulty Level: 2
Lock repair
So you have had the boot light stop working or message on the dash.. You might be able to repair this for a couple of quid
(Be aware that if you muck this up your boot catch will be unusable so check your local dealership is open and they have a boot catch on the shelf should the worst happen before you start
So first you have to get into it carefully unclip the clips try not to snap them although im sure you will the plastic is a bit brittle (Chemical metal or epoxi such as Aradite is your friend on reassembly )
Now withdraw the motor its held in place by 2 spring contacts to the Printed Circuit Board (PCB)
give it a wiggle and a pull and it will come away...
You could now try contact cleaner directly on to the micro switch.. if that fails replace it with a solding iron obviously
Now thats out its time to be brutal The way the lock is assembled should stop you removing the PCB (in theory) But well..........
Take a dremal and a milling bit or sanding drum or cutting disc and get trimming
you need to remove a bit of plastic from here...
like this take care not to damage the PCB
Now for the delicate hooliganism the last thing holding the PCB in place is a plastic tag which holds the Microswitch to the plastic body of the lock but insert a screw driver with care and give a bit of "persuasion"
you can see the snapped of plastic peg here...
and the part number for the microswitch which should be obtainable on line.. but first try soaking it in contact cleaner
Finally rebuilt this lock with a new switch soldered In place and packed the lock full of lithium grease to hopefully keep water out
old and new switch (switch cost me 1)
Thanks Sean23491 thanked for this post
Likes Flshbckmn liked this post
Contents
<<  <    (Page 2 of 2)    > >>
Old 07-05-2015   #1
Re: Boot locking mechanism replacement / Repair
Glad I found this. Punto tailgate latch failed "open" as we were about to leave in another car for 600 mile trip. Had to back Punto tight against wall and fit wheel clamp for security while we were away.
Followed your instructions on return and managed to free sticky solenoid sufficiently to latch and lock tailgate.
New Fiat lock now on its way from Germany at half the price of second hand ones in UK.
grandpunter is offline Reply With Quote Quote
Old 29-06-2017   #2
hi, my boot wont open after my other half slammed it shut...i changed fuse but it went straight away ...do you think that replacing it would sort it out??
gillm is offline Reply With Quote Quote
Old 22-07-2017   #3
nikrox has donated!
fuse?..which fuse?..
nikrox is offline Reply With Quote Quote
Old 14-01-2018   #4
Thanks for the guide. I've completed this job myself this weekend. My old lock was well corroded, so I replaced it with a new unit. Also needed to replace the fuse as it had blown.
For reference the fuse is a 15AMP in the dashboard fusebox. I have the glovebox fusebox and the fuse in number 6.
Englishlion is offline Reply With Quote Quote
Old 04-03-2019   #5
Sweden
Are the non-genuine replacement locks worth anything, or do I have to get a "ricambi" one?
Used to own CCS 1.2T, now it's gone
woj is offline Reply With Quote Quote
Comment
Guide Tools
(T) Boot mechanism robk77 Grande Punto 24 26-05-2018 15:43
(T) Boot mechanism... Oscar Panda (2012+) 145 26-03-2014 19:02
(G) sliding door locking mechanism caledonian1 Doblo 2 06-12-2009 09:46
(G) Rear boot electric locking mechanism Oscar Panda 4 29-05-2007 07:47
(G) Replacement Sunroof Mechanism? tonyfurnell Uno 10 19-10-2005 10:16
