Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Drivers side Window switch removal and clean<!-- google_ad_section_end -->
Published by lou5590
05-08-2013
Difficulty Level: 1
User Rated:Unrated
Firstly. I have done this on my own car. You follow this guide at your own risk. I am not resposible for any damage done to your car or person.
Ok quite simple really take a flat blabe to the drivers window controll panel. i found it easier to leaver it in from the back and the side closest to your legs.
(on pic indicated by RED arrows)
there are 2 metal clips that you need to squeeze in to remove the control panel
(indicated by BLUE circles)
ID:	121992 - 1
now take off the electric connectors, there are two a long white one which should just pull out, and a blue one. for this one you have to push the black part down this releases the connector. Now the window switch is free to come out
now flip the controller upside down. you will see a large yellow plastic part this houses the circuit board, led's, and 4metal rockers, to take this out, you need to leaver it out with a flatblade. Best way to do this is to insert your flatblade at the side and hold it yellow side down in your hand. then leaver it out. This is because the 4 rockers are loose they can fall out and get lost.
Name:	pic upside down.jpg
ID:	121991 - upsidedown
Name:	pic rockers.jpg
ID:	121990 - picrockers
now this is a pic of mine. As you can see it looks like mine has actually burnt under one of the rockers on the passenger side
Name:	burnt connector.jpg
ID:	121993 - burnt connector
now to clean mine i used some tissue paper, a cotton ear bud will do fine. Gently clean the metal connectors, as much as you can im sure other people will say use some sort of liquid but this was fine for me
now for reassembly, keep the yellow part in your hand, circuit board and rockers facing up, and with your other hand pick up the other part of the controller, try to keep the window switches in the middle, this allows for easier reassembly. then pop back in the yellow part.
Reconnect the connectors in the door and FIRMLY push the window switch back into the door card and test.
This sorted my problem with the intermittent window operation
hope this helps
Thanks Thomas487, DJS thanked for this post
Likes Lokie, Thomas487, DJS liked this post
Old 2 Weeks Ago   #1
Re: Drivers side Window switch removal and clean
Big thanks. Just done this. Cleaned the contacts under the rockers and the windows are now working perfectly.
JohnnyMac999 is offline Reply With Quote Quote
Comment
Search this Guide:
(T) Drivers window switch bluepunto8v14 Grande Punto 1 09-06-2013 09:57
(G) Drivers side window Blue boy Punto (Mk2/2b) 6 20-10-2011 21:29
(T) Drivers Window Switch needed Bravo_Pro Marea 0 27-11-2009 12:12
(G) drivers side airbag removal gstar1 Grande Punto 27 29-04-2009 10:18
