Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Replace the Diesel Fuel Filter<!-- google_ad_section_end -->
Published by MKoers
06-03-2012
Difficulty Level: 1
User Rated:
Difficulty Level: 2
Tools/Parts needed
I have replaced the fuel filter of my 1.9 JTD Grande Punto, as there wasn't I guide I made some pictures to create one.
What do you need:
Rattle with a 10mm socket
12mm wrench
Cloths
Flat screwdriver
Contact spray
A new fuel filter
Bucket
Name:	New Fuel Filter.JPG
Thanks DJS, sparks, Quboffin, matty seasider, Andy Monty thanked for this post
Likes DJS, varesecrazy, Summerjunk, Vento, jarmer and 2 others liked this post
Contents
<< <    Next Page: Remove the old Filter (Page 1 of 5)    >  >>
Old 21-06-2012   #1
CSR dog has donated!
Re: Replace the Diesel Fuel Filter
Done y'day, 10 minute job and well worth it, my filter was the original fitting and has done 58k! Performance is totally different, no sluggish or hesitance on acceleration, air filter changed as well.
Fuel Filter 23 & Air Filter 8.54, both off ebay.
CSR dog is offline Reply With Quote Quote
Old 04-07-2012   #2
Denmark
Hello
It is a good guide, which can also be used on a Fiat Doblo 1.3 2010
jarmer is offline Reply With Quote Quote
Old 14-09-2012   #3
Greece
hi i change the same filter with you but the warning light still on.a mechanic say i must change and sensor whrere can i buy chip?to e-bay i cant find it.thanks
nounoss is offline Reply With Quote Quote
Old 10-12-2012   #4
Great article this.
I've just done mine so this is how i did it. Dont remove any fuel pipes.
Unclip the electical connector on top of the filter unit.
Place some plactic sheeting under the unit to catch the spilt diesel.
Use a hammer and block of wood to undo the filter cap tapping gently until it starts to move. Once loose, unscrew. It unscrews ANTICLOCKWISE
Lift screw connector out of the way and lift the filter assembly out of the filter housing. this is where the desiel gets spilt
Take the old filter off and stick the new one on.
change the 'O' ring on the housing for the new one.
Gently put the assembly back into the filter housing an allow the filter to soak up some desiel.
Put the screw connector back on and tighten it hand tight.
Clean up any desiel spilt
Get your block of wood and hammer and start tapping it clockwise. It is going to have to be very tight so gently but firmly.
Once happy reconnect the electical connector and fire up the ignition to active the pump and check for leaks. If its leaking keep checking it and tapping it until it stops. Always clean the desiel up after you. the filter top has to be very tight.
I did it without even taking the unit out of the car and didnt disconnect any pipes. No leaks and the car drives notacibly better particularly before the turbo kicks in. I changed the air filter as well at the same time.
Hope this helps others. So long as you use some common sense its an easy job.
Tubularowl is offline Reply With Quote Quote
Old 05-02-2013   #5
Sweden
Hi there had the same problem , just changed the fuel filter started the engine and the engine light has appeared and stays lit in the instrument ......so I forgot to bleed the filter which I did via the bleed valve but it didn't have an effect until I unclipped the thick fuel line, I heard the filter gurgle away. sorted no more engine light !!!!
swedgrande is offline Reply With Quote Quote
Old 11-11-2015   #6
Which bit is the vent to bleed the air from the filter?
Bruno SLOTTS is offline Reply With Quote Quote
Old 07-08-2020   #7
varesecrazy has donated!
The system Self Bleeds
Turn the ignition on..
Let the fuel pump tun a few cycles
CHECK FOR LEAKS
then start the engine
MUCH easier than the old mechanical injectors.. air locks were a pain
varesecrazy is online now Reply With Quote Quote
Comment
Search this Guide:
(T) how to replace the fuel filter element on a 2007 ducato 2.2 appleyard Ducato 1 19-05-2010 22:32
(T) Diesel weeping from fuel filter plus broken fuel pipe arrhythmia rules Panda 3 24-01-2010 23:12
(T) Doblo 1.3d multijet cargo fuel filter replace Pinta Doblo 0 04-01-2009 10:50
(T) fuel and filter replace WINDMASTER X1/9 1 24-03-2007 20:37
