Comment
Guide Tools Search this Guide
Replacing the bulbs in the heater controls
johnlad27
23-02-2012
This is a fairly easy task to complete, just be carefully of the sharp metals behind dashboard.<br />
<br />
Tools needed:<br />
<br />
Various Screwdrivers, Flats, posi's and Torx bits.<br />
Ratchet bar<br />
Pliers<br />
The bulbs are here ...
Old 05-03-2018   #30
Re: Replacing the bulbs in the heater controls
my car is a 60 reg if that makes a difference
MattoW is offline Reply With Quote Quote
Old 05-03-2018   #31
been fiddling with it tonight, not taken anything apart,just twiddling the dials and it seems to have got the lights back working again....v.strange. The lighst have been playing up for a while, working then not working, then back working and now not working again for a couple of days until my fiddling about tonight. Any reason why they may be doing this? Have also noticed for a while now that the left hand side of my rev counter dial on dash sometimes looks less bright than the right hand side of the dial, and the fog light/dimmer buttons on the panel to the bottom right of the steering wheel is also sometimes very dim, but tonight has seemed reasonably bright and steady. Do I have a series of minor gremlins going on with my electrics behind the dash? I have a airbag warning light on too, although a garage has used diagnostic on this and its showing a "clock spring/squib/airbag spiral coil" fault and needs replacing, could this also be causing my other gremlins?
Old 07-03-2018   #32
varesecrazy has donated!
Quote Originally Posted by MattoW View Post
Hi, just been reading this thread and seen how somebody mentioned that replacing these bulbs on a Punto Evo is different to how the original post describes. I notice above that someone mentioned that there is a guide in the Evo/2012 section for this, but I can't seem to find it. I have bulbs on my heater selection dial out.. Anyone able to help of point me in the right direaction to find a guide/fix?
cheers
That ref. To 2012 was me...
I seem to recall a scandinavian member did the job and added some useful info.
SEARCH the threads for relevant terms..
Glad to say Ive not needed to touch my 2012..
TBH.. your issue sounds like a loose contact..or dodgy earth..
The clockspring should'nt be related...
But of course it MAY mean the wheel has been off before..adding to strange occurences.
Old 24-11-2018   #33
So I was stupid enough not to look up how it's done... now all the clips have snapped!! any way I can change these or find a way to do the same thing as the clips were doing? (Not held in together as tight as before)
G17BOC is offline Reply With Quote Quote
Old 13-09-2019   #34
Get a wriggle on!
levemircento's Avatar
levemircento has donated!
just carried out this job on mine, now all working.
ta
must be time for a brew
levemircento is offline Reply With Quote Quote
Old 26-12-2019   #35
Anyone know where the fuse is for these bulbs Iíve replaced the bulbs but they still ainít working my head is baffled 😕
Herbe is offline Reply With Quote Quote
Old 26-12-2019   #36
chris3234 has donated!
Quote Originally Posted by Herbe View Post
Your checking with the lights on arnt you?
chris3234 is offline Reply With Quote Quote
Old 26-12-2019   #37
Check for power..
I would be astounded if they are on a separate fused supply..
Poor plug connection somewhere
Old 27-12-2019   #38
I changed the bulbs and yes I turned on the lights 🤣 still wasnít working so thought there might have been a fuse that may be out not a major problem but I like to have the car In decent nick for when itís being sold so any help would be perfect right so just throw answers of what it could be right at me
Old 27-12-2019   #39
Quote Originally Posted by varesecrazy View Post
Check for power..
Where would this plug be pal
Old 30-03-2020   #40
GPSporting2009 has donated!
Great posts as I need to do mine, although not urgent
GPSporting2009 is offline Reply With Quote Quote
Old 30-03-2020   #41
Hi All,
great tutorials, need to do mine soon, although not urgent.
I may try getting at em thru the lower panel.
Old 31-03-2020   #42
Good luck.. and feel free to add pics/info
Didnt get far on the one I tried
Old 09-11-2020   #43
I've just got a Fiat qubo fully refurbished. Lovely, but the climate control lights are out. Now ive done some research about replacing the bulbs but it appears some fiats have the dials removed first and others the whole panel comes away. Ive posted a picture of it if anyone can help
Kenmcd is offline Reply With Quote Quote
Old 09-11-2020   #44
Quote Originally Posted by Kenmcd View Post
Hi Ken.
That isnt CLIMATE..
Climate tends to be all digital with up and down arrows
But.. thats probably a good thing
Look in the parts diagrams.. to see where the panel separates.. it looks fairly similar to a Grande..
But I got nowhere looking to change my bulbs..
Comment
Search this Guide:
replacing stereo for Fiat Ulysse with steering wheel controls chimpo I.C.E 0 01-05-2010 21:01
(T) Heater controls bayley84 Punto (Mk2/2b) 6 01-02-2009 17:38
(T) heater controls not working g4ree Punto (Mk2/2b) 3 15-09-2008 00:04
(G) Heater Controls Gary196721 Scudo 3 16-12-2007 22:39
(G) Heater controls Howard Cinquecento / Seicento 5 05-09-2005 21:17
