Comment
Guide Tools Search this Guide
1.2 8V EVO 2 Engine Cam Belt replacement
A time consuming job...
Andy Monty
22-05-2010
Right First off this is an involving task requiring some specialist tools and a bit of care and attention to detail get it wrong and there is a risk of serious damage to your engine....<br />
<br />
<br />
Tools/ equipment needed <br />
Old 14-06-2015   #30
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: 1.2 8V EVO 2 Engine Cam Belt replacement
Updated with vvt info and water pump change details
Old 13-09-2015   #31
Quote Originally Posted by Andy Monty View Post
then tighten the cam bolt to 180-220NM +55 degrees (which is flipping TIGHT)
Thanks for the guide, but I am not sure about this torque value.
For the Punto Evo 1.4 8v VVT:
Fiat Elearn says 1.8 to 2.2 daNm (this is 18 to 22 Nm) + 55 degrees.
and the new Punto Evo Haynes manual says
stage 1) tighten to 20Nm,
stage 2) tighten a further 55 degrees.
homersimpson is offline Reply With Quote Quote
Old 14-09-2015   #32
Moderator
Andy Monty's Avatar
Quote Originally Posted by homersimpson View Post
my / sealeys mistake ive just checked on elearn
However i was going by the figures on my cam locking kit from sealey and it does give 180-220nm me thinks i avoided a very expensive mistake by the skin of my knuckles...
i have amended the guide accordingly
Massive gash
Just a little touch up
Old 14-09-2015   #33
Moderator
Andy Monty's Avatar
See here me thinks they cocked up
Thanks Pugglt Auld Jock thanked for this post
Likes Pugglt Auld Jock liked this post
Old 14-09-2015   #34
They certainly did. I would have expected better from Sealey.
Glad you break anything
Old 14-09-2015   #35
Moderator
Andy Monty's Avatar
well i only found the other half of the torx bit last week
Massive gash
Old 20-01-2016   #36
Does anyone have an Amazon / Ebay link to where I'd get the Cam Lock kit from for the 1.2 8v 2006 Grand Punto? or is it a Universal Jobby?
nturnb is offline Reply With Quote Quote
Old 27-06-2017   #37
Thanks for the guide as i will be attempting this soon.
I have a question though - what is the need to slacken off the cam pulley - i.e. this bit;
"next slacken off Cam pully
FIRST REMOVE CAM LOCKING TOOL or you can damage your camshaft end
loosen using a 24mm spanner on the flats on the cam shaft and a T55 torx socket)
Surely if the you've managed to get the locking tools fitted to the cam and crankshaft there is no need to touch the cam pulley as it should already be set?
Or am i missing something?
I have done a Vauxhall 1.6 engine before but i would just like be sure before i start.
u33db is offline Reply With Quote Quote
Old 26-08-2018   #38
Vatican City
Cool Re: 1.2 8V EVO 2 Engine Cam Belt replacement
1. Yes, that doesn't make sense, to "slacken off the cam pulley". No need for that.
Some folks do it (probably) just because it is inconvenient to put new belt on ("thread" it around all pulleys).
2. You don't need special tools. It still can be done classic way (marks, magic marker/sharpie, paint), a bit harder, but doable. Also no need for "special" alignment tool for camshaft cover.
Russians do it like this (part 1, belt removal): and part 2 (fitting new belt): don't listen just watch carefully.
3. And no one even tried to copy timing belt tools? Looks like an easy bolt hole pattern, and linear dimensions are not critical (angles are - that's the main purpose of locking tools/jigs).
Camshaft locking tool seems to be exactly 10 degrees (most important number here), rest you can figure out by yourself...
Reverse engineering based on pictures works pretty well. Nice round numbers pop out.
You can also guess accurately dimensions if you try.
To make yourself a copy, use flat-bar, no need for "lollipop" shape. Holes can be slotted (so you don't worry about accuracy, at least in terms of linear dimensions - but mind the "clocking").
Guess what. It's a FIRE family. Some things ain't change. This is crank pulley/cog from Punto 1. Same dimensions. Only number of tooth differs.
Everything fits, same numbers (Punto 1 = Grande locking tools dimensions extracted from pictures).
Bolt hole pattern is...you guess...the same. Measurement and some math.
So, you get the idea. Using basic metalworking/machinist skills (layout/scribing, drilling, filing) you can attempt making your own "timing belt kit" set. No rocket science.
Example 3D model: CrankLock_(dimensions_based_on_pictures).zip
Likes Pugglt Auld Jock, SRafferty liked this post
GrandePunto PL is offline Reply With Quote Quote
Old 28-01-2019   #39
Superb. Many thanks.
Simon
SRafferty is offline Reply With Quote Quote
Old 29-01-2019   #40
varesecrazy has donated!
Quote Originally Posted by u33db View Post
The idea is..
You bring the piston up to TDC
AND get the camshaft in time with this
(Then shifting the cam wheel timing marks to get back in sync.)
Of course this timing is ALREADY likely to be correct.. as the engine has been in use for years.
BUT. If you are looking for 100% accuracy.. then yes it is worthwhile.
NOTE:
The CRANK AND CAM have sensors for the electrical pulse timing.. this can
shift : be offset a little... with the marginally shorter length of a new timing belt.
Often this mismatch can cause an MIL warning.. and will require a Phonic Wheel Relearn
To bring the 2 signals into a range the ECU
Can cope with.
Old 01-02-2019   #41
Vatican City
Post Re: 1.2 8V EVO 2 Engine Cam Belt replacement
I've bought some cheap tools (for 1,2 and 1,4 8V Grande engines) to inspect them.
My "measurements" from pictures were just a bit off. Here is a real thing.
CrankShaft tool angles are roughly OK (didn't bother to measure this). Looks good enough.
CamShaft tool angle is exactly 10 degrees (as "reverse engineered" from pictures).
Such things (timing belt job set) are not precise...you can copy them using school/office tools (like protractor). Seriously.
Rough check (not complete drawing yet), maybe I will do the 3D model later.
As you can see, it is possible, to extract good numbers from the pictures and copy such tools. If you are technically inclined enough to do this, you will also figure out other parts from timing belt kit.
Old 02-02-2019   #42
Vatican City
Arrow Re: 1.2 8V EVO 2 Engine Cam Belt replacement
Update. The 3D models.
Rough sketches.
Download: TimingBeltTools(Crank&CamShaft).zip
Old 06-02-2019   #43
Vatican City
Talking Re: 1.2 8V EVO 2 Engine Cam Belt replacement
Russians are crazy, in a good way. They treat those engines like any old FIRE. Just set it at TDC, and that's it, job done. Such position is probably very stable (nothing should move, camshaft under valve springs pressure & VVT internal spring). Assumption is: engine is/was running fine (belt has not skipped a tooth).
Tools for Grande are not TDC-setting on purpose. Mostly to avoid crashing valves into pistons.
Comparison to old Fiats (like Punto 1).
Probably more than VVT can move (rotate), which is around 30 degrees.
Same idea is in the 16V engines (2 rods are there, to set pistons in mid-point/stroke, away from valves).
If you want to use tools, easy way to make your own is a printing in 1:1 scale (DWG file).
Then drill and file (biggest hole) in a piece of flat steel bar/sheet. Done.
Camshaft locking tool will be little bit more complicated... Stay tuned.
Last edited by GrandePunto PL; 06-02-2019 at 09:38. Reason: Camshaft tool making ("homebrew") will be later.
Old 14-02-2019   #44
Vatican City
So, here is an example of DIY crankshaft locking tool. Flat bar.
Example of DIY camshaft tool. Prototype was made from right angle profile/bar, 20x20 mm and 3,5 mm thick. Better use next size available, will be more stiff (let's say 25x25 or 30x30 and 4 to 5 mm thick). Piece "clocked" at 10 deg. angle is secured with two small bolts (if you can, use welding instead).
Last thing is a VVT wheel lock, the least important part of the timing belt tool-kit.
Dimensions don't matter much, make it slightly oversized and fit (file it, grind it, enlarge the hole) while working on the car.
By the way, here is another example of timing belt swap, done classic way (cyl. 1 at TDC).
Let's call it "German method":
SlideShow, English description. Only one tool was used (crank tool).
"Brazilian method", version 1: cam and crank tools, plus VVT loosened (without locking it).
Version 2: also two main tools, but without messing with VVT (VVT ignored).
Other example:
Educated guess: full set of timing belt tools and fairly (over)complicated official procedure are probably taken straight from the factory assembly line, where they put these engines together the very first time.
So you don't have to "jump through hoops" (slacken VVT, etc.), when you just want to swap the belt (and engine was working fine beforehand).
Comment
Search this Guide:
(G) Cam belt replacement Murray Ducato 8 13-08-2014 11:44
Cost of Cam belt replacement Phillip J Fry Garages 1 19-11-2008 13:25
(G) Cam belt replacement eryan Ducato 0 01-01-2008 16:41
(G) Cam belt replacement Barchetta27 Barchetta 15 17-10-2007 21:32
(T) Cam Belt replacement, what else should be done? Kelbert1066 Multipla 0 31-03-2007 18:45
