Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Protecting your ABS Unit from water ingress and corrosion of connection block<!-- google_ad_section_end -->
2 mins to save yourself the posibility of a BIG bill...
Published by Andy Monty
09-04-2009
Unrated
User Rated:Unrated
First for general safety disconnect the battery and leave 10 mins....
now get hold of a suitable dewetting and anti corrosion spray or contact cleaner and lubricant....
Surprise surprise i opted for Bilt Hambers Ferrosol (which imo is far better than WD-40 and the like)
anyhow
Locate the ABS control module on the upper right of the engine bay between the battery and the fire wall/bulkhead
next Locate the release tab on the connector (on the right) slowly pull this tab up all the way till it goes back on itself This lifts the Plug off square and reduces the risk of bending any pins....
now with it off check for any water if present wick away using a paper towel....
give a light spray to the pins (Don't flood the connection just a mist is all that is needed)
and repeat for the plug itself
Next dab the areas dry to remove any excess de-wetting fluid
now to refit the plug (first check the orange seal is sat properly)
Ensure the plugs release lever is folded right back (so it's laid flat against the cable end of the plug
line up and push down slightly then bring the lever over the top till it snaps back down on the right ensure all the hooks are located on the locking pins then reconnect the battery
Sound complicated? watch this....
Then start the car reset the clock and pray the ABS light doesn't come on
Old 09-04-2009   #1
Gerrit up ye!
powered_up_pac_man's Avatar
powered_up_pac_man has donated!
Re: Protecting your ABS Unit from water ingress and corrosion of connection block
Good guide mate, is this corrosion issue likely to happen? Know of anyone that's had problems?
Donate to FF | Buy FF Merchandise | Classifieds | FF Insurance | How-to Guides | FAQs
powered_up_pac_man is offline Reply With Quote Quote
Old 09-04-2009   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Quote Originally Posted by powered_up_pac_man View Post
https://www.fiatforum.com/grande-pun...s-problem.html
Massive gash
Just a little touch up
Old 09-04-2009   #3
Trader Rating: 2
colin79666 has donated!
like the vid!
a picture tells a thousand words
a video clip tells 500 words and 5 captions
colin79666 is offline Reply With Quote Quote
Old 20-08-2012   #4
Australia
Great guide and it really does only take 2 min. Worth it for the peace of mind.
cafe77 is offline Reply With Quote Quote
Old 12-08-2018   #5
Thx for the post and the video. My 1.3 multijet (90) wiring that leads from the battery to the abs unit is always wet when it rains. Does anyone know where the water is leaking from to get onto the wiring in the first place, thinking it maybe from the passenger side windscreen drain?
Anyone with the same problem or some clues? Thx
Mw99 is offline Reply With Quote Quote
Comment
Search this Guide:
(T) Water Ingress phostead Grande Punto 21 16-08-2008 20:05
(T) water ingress folgore Stilo 0 08-03-2008 12:26
(T) Brava water ingress justin.accurate Bravo / Brava 13 23-06-2007 01:25
(G) Water Ingress seanb Ulysse 1 20-09-2006 21:56
(T) ABS Pump corrosion Missfitz Punto (Mk2/2b) 0 21-05-2006 13:42
