Comment
Guide Tools
<!-- google_ad_section_start -->How To Replace Stock Springs Front + Back<!-- google_ad_section_end -->
Easy Enough For Any Amature
Published by DannyBoy88
23-02-2009
Difficulty Level: 4
User Rated:
Difficulty Level: 3
Swap Out Rear Springs
Removing ( Refitting ) Rear Springs
- Position the vehicle on a lift.
Name:	remove refit rear diagram.JPG
1. Place a hydraulic lift under the rear crossmember by the spring.
2. Undo the bolt securing the shock absorber to the suspension crossmember.
3. Slowly lower the hydraulic lift until the spring is not compressed and remove it.
Do the same for the right spring.
Refitting New Springs
- Place a hydraulic lift under the rear crossmember by the spring seat.
- Place the spring in its housing.
- Raise the hydraulic lift slowly until the shock absorber lower mounting is in line with its housing in the crossmember and then secure it tightening the bolt to the recommended torque.
Bolt Is M12 Tightened To 11.7 14.3 daNm
- Slowly lower the hydraulic lift until the spring is not compressed by the lift.
Thanks DickieP, omega22, User Not Found, Dukeman, 1steamon1 and 1 others thanked for this post
Likes DickieP liked this post
Contents
<<  <    Next Page: Swap Out Front Springs (Page 2 of 4)    >  >>
Old 17-08-2009   #1
Dukeman has donated!
Re: How To Replace Stock Springs Front + Back
This great guide gave me the confidence to tackle this activity. One other tool required is an allan key for the top of the front shock and a screwdriver to access the top of it. Followed it and managed to complete the whole change with cleaning wheels etc in around 3-4 hours. Got a bit stuck when allan key split the end of one shock so need help with airgun to remove and replace the bolt.
Many thanks for the guids.
Fiat the new Audi
Dukeman is offline Reply With Quote Quote
Old 16-10-2010   #2
Can anyone convert the torque settings to newton meters?
Half way through doing this and got stuck after not being able to understand the torque settings haha
CBass is offline Reply With Quote Quote
Old 27-09-2011   #3
When does it end..?
tjetface has donated!
Great guide, however to remove the damper, shock... Whatever it is for the rear spring bolt, u need, or at least for my 57 plate, a star socket. An E18 it is called, popped into fiat about it and asked the mechanic as with the thousand sockets I have lying around like I imagine most going to tackle this, wasn't in my collection. Cudnt even take a propa look at the bolt as didn't trust my axel syands with my life so I hope this helps. Spot on guide though it turns a minefield into an ikea cupboard instruction sheet!
tjetface is offline Reply With Quote Quote
Comment
Guide Tools
(G) Eibach & Weitec springs back to back. GoBe Cinquecento / Seicento 7 30-05-2008 11:28
(T) Another way to replace front speakers... Proc Stilo 8 12-03-2004 18:48
