im Axle Specialists
Comment
Guide Tools Search this Guide
How to Install / replace the Pollen/Cabin filter
Step by step guide to Replacing or fitting a new pollen filter
Andy Monty
04-06-2008
No really tools are needed apart from a small paintbrush and a Hoover with a crevice tool..<br />
<br />
The Replacement Interval of the filter varies obviously with the environment the car is used then again a quick hover regularly can eek a bit more life out of the filter as OEM replacement is
Old 18-09-2011   #30
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: How to Install / replace the Pollen/Cabin filter
If tag at top breaks just use a small self tapping screw to secure.
Old 03-12-2011   #31
1.4 16v Nissan Note Visia
Magic Johnson's Avatar
Magic Johnson has donated!
Just checked this and mine doesn't have a filter.
Magic Johnson is offline Reply With Quote Quote
Old 01-01-2012   #32
Bulgaria
wow thanks i have to replace my filter and i was wondering how to do it.
Thanks one more time
thegame is offline Reply With Quote Quote
Old 27-02-2012   #33
Quote Originally Posted by Andy Monty View Post
The Replacement Interval of the filter varies obviously with the environment the car is used then again a quick hover regularly can eek a bit more life out of the filter as OEM replacement is 18ish
First you need to Locate the Filter its hidden behind the trim in the passenger side foot well (UK)
to gain access you first need to remove the trim
put your fingers under the trim near the false vent and pull away
Attachment 48797
once released along this edge pull the trim towards the back of the car
as the front edge is held in place by a hook which locks into the side of the heater control unit until it comes free
Attachment 48798
next look for the filter cover
Attachment 48799
this needs to be unclipped (some might have a retaining screw air con?? but my active didnt? )
Attachment 48800
Once the cover is removed remove the old filter (if fitted in the first place) then use a small artists paint brush and a Hoover to remove any debris
Attachment 48801
next insert the new filter (i gave mine a light squirt or AutoGlym Auto fresh on the inside of the filter element)
(airflow indiator on the filter needs to point into the car /towards the back of the car)
Attachment 48802
Attachment 48803
This is a bit of a pain to get in you need to push the top edge then the bottom bit by bit working alternately
Attachment 48804
once fully home you need to refit the cover (this has a wrong and a right way)
this is the bottom edge
Attachment 48805
you need to hook the top on first after pushing the filter slightly further in with one hand whilst locating the top catch (as it expands tight against the cover to make an air tight seal)
next hinge the cover down and clip the lower on (refit the screw if fitted)
next refit the trim by hooking the front hook onto the side of the air box
then reclip the rear section back in place
And thats it
ONE LAST THING
remember the heater matrix pipes will be HOT if the car has been used just before fitting it made me jump
Hope this helps
just to add just replaced it again and got an after market FRAM branded filter
Part#CF10282 cost just shy of 5 from local indipendent factors
Ref the pollen filter in the Grand Punto.
If it's clogged as mine may be, as the air flow seems to be reduced, would that stop the air-con from operating. Is there some sensor that would stop it from switching on?
Mike Eager is offline Reply With Quote Quote
Old 01-03-2012   #34
Australia
Question Re: How to Install / replace the Pollen/Cabin filter
Excellent information the photo's were great! next hurdle, how do you remove the glove box to replace the fan unit?
LenV
LenV is offline Reply With Quote Quote
Old 13-07-2012   #35
CSR dog has donated!
Excellent guide, cheers mate
CSR dog is offline Reply With Quote Quote
Old 13-10-2012   #36
Thanks very much for this guide - really helpful.
Putting the new filter back in was an awkward affair to say the least in which at one point I almost gave up, risking damaging the filter.
Funny thing was after spending ages fiddling around trying to stuff it in & getting nowhere - had one last attempt & it went in easy.
Still don't know where I was going wrong.lol
Thanks again.
Alfiaferrmazza is offline Reply With Quote Quote
Old 01-12-2012   #37
Getting the old filter out was really easy. Getting the new one in...
Not sure I've done it properly, as it seemed to be folding up, but the main thing is that with the fans on, especially on 4, I can actually feel air coming out. Rather than the asthmatic gerbil which used to cough in my direction. Haven't been for a drive yet, but hopefully it might even feel warm.
The old filter was a bit grey on the car side but sooty looking on the other, so I'm not surprised no air was coming through. If anyone is suffering with poor airflow, it's definitely worth checking the filter
DueUno is offline Reply With Quote Quote
Old 04-02-2013   #38
Excellent guide, just done mine and, as per other comments, no filter installed, no wonder i choke in the city fumes!
like so many before, i snapped the top clip of the housing cover and taped it back on, i assume there isn't sufficient heat in this area to cause any smouldering?
07 GP 1.2 Active, owned from new.
Trailpimp uk is offline Reply With Quote Quote
Old 05-02-2013   #39
Moderator
Andy Monty's Avatar
Andy Monty has donated!
No it's pre heater matrix and even that won't get hot enough yo cause an issue
Massive gash
Just a little touch up
Old 25-02-2013   #40
Cheers Andy, will be attempting this tonight on my AGP
I am assuming the steps will be 95% if not 100% the same!
TallTom is offline Reply With Quote Quote
Old 23-03-2013   #41
Hi, in desperate need of assistance with this.
I have a 2004 1.4 Stilo (active) A/C
i have ripped both panels off the footwell on both sides, and after several attempts I CANNOT find the pollen filter housing, I am starting to think this car doesnt have one.
But the fans have got reduced flow, starting to smell a bit funky and feel not too well after driving. all pointers to clogged polen/cabin filter.
Please can somebody give me some definitive guide on where it is located.
I can get some pics of both wheelwells and maybe somebody could mark on the pic where exactly it is located, then after that is done i just need to source two new panels as the ones i took off are ruined..
any help greatly appreciated
stelarge is offline Reply With Quote Quote
Old 23-03-2013   #42
T-Jet!
Sweex's Avatar
Sweex has donated!
Re: Re: How to Install / replace the Pollen/Cabin filter
Quote Originally Posted by stelarge View Post
This is a guide for a grande punto not a stilo?
My Grande Punto T-Jet Daisy
Sweex is offline Reply With Quote Quote
Old 24-03-2013   #43
Moderator
Andy Monty's Avatar
https://www.fiatforum.com/stilo-guid...ow-remove.html
Massive gash
Old 22-08-2013   #44
This was really helpful, thanks to the originator of the thread. It's been really boring driving with the ventilation controls on either 4 or off and hopefully less of the dirt will get in (of course one of these were noticed when the car was serviced!)
aerodinamismo is offline Reply With Quote Quote
Comment
Search this Guide:
(T) Cabin Filter lola's dad Multipla 1 27-10-2007 21:16
(T) Cabin filter ts86net Marea 13 01-03-2007 14:25
(T) Pollen filter=cabin filter? waynem325 Stilo 5 17-10-2006 19:28
(T) Cabin Filter 1.8ELX hatters1999 Bravo / Brava 10 25-05-2004 04:42
(T) Cabin filter M@XI Stilo 2 21-04-2004 01:19
