Uno My Fiat Uno Turbo MK2 -87
Some info about my Uno:
Engine and transmission:
* Half V8 on 1301cc. =)
* Malpassi "384" Progressive BTR 1,2:1 (2.9 bar ground pressure with vacum)
* Custom built 360 degrees stored hybrid turbo (IHI RHB 5/6)
* A-25 Hybrid BOV from JB Raceparts.
* Aluminium intercooler från KL-Racing, Width:60cm Height:30cm Thickness: 7,6 cm. 3" connections.
* Direct air filter
* 2.5" exhaustsystem from the turbo without catalyst.
* 5 gear original gearbox.
* OMP pressure plate
* OMP sinterlamell clutch
* Front mounted oil cooler.
* New engine mounts
* Walbro 255 l/h fuel pump
Chassies:
* Fully Koni and Jamex suspension around the car
* Lowered 60 mm around the car.
* Super flex bushings around the car.
* Omp Rollcage
Tires and brakes:
* Street Tires: Federal SS-535 (185/65 R 14)
* Track tires: Maxsport Semi Slicks (185/65 R 14)
* Slotted EME-TI brake discs
* EME-TI brake pads fram around the car.
Interior:
* 1 Sparco sportseat and one lancia delta seat.
* Homemade seat bracket.
* Momo streering wheel
* OMP four points seat belt + the original.
* 5" Tachometer.
* 52 mm Boost gauge.
* 52 mm electronic fuel pressure gauge.
* Battery moved to the spare wheel pod
* Soon to be installed: 52 mm lambda gauge
Future plans:
Right now I'm renovating the engine with new parts in the engine.
I'm also changeing the gearbox because the old one got some cracks after some rough driving. Unfortunately I can't make the tuning this winter that I wanted to do because of my economic situation. (Out of job right now.)
The engine when I first got the car.
A while after i got the car.
My 2 hood designs, very proud of them. =) I'm going to make a new this winter. :slayer:
:devil:
Fiat to the left and Volvo to the right, cute ? (y)
Fiat to the left and Volvo to the right. (y)
Puting on some new colour. :worship:
All for now, I can update while I'm working on the car if you are intressted ?
Have a good day / Timmy :)
Vehicle information
FIAT Cars
timmyr
Views
18,702
Last update
More in FIAT Cars
