Punto (Mk2/2b) A grey and hopefully colorful daily driver Punto
My second Punto mk2 !
Because, even though the first Punto was totally worn down, it proved to be quite easy and cheap to maintaine, and having good mileage (km/l), and perfectly roomy for all my different equipment.
https://www.fiatforum.com/members-motors/429269-pretty-worn-year-2000-mk2-5-door-punto.html
But it was crap riding, and when the HG blew, I was just to happy finding a better example.
And I did. A grey, rather conservative style 1.2 16v from year 2000.
Ok interior.
And aloys, that needs a lot of love, but looks ok from distance.
The Fiat had some errors.
A cracked set of rearlights, that I just swapped from the old Punto.
A set of wintertires from the old Punto.
Bonnet release was snapped and I used 10 minutes to replace it with a new.
The frontbumper is heavely scratched when they tried to open the bonnet. Getting it painted next year, after the winter.
Though mostly rust free, it needed a lot of rustproofing to make it through the winter (Danish winters are agressive saltridden anticar winters...)
Just passed MOT, it actually has a small rust issue in the right side bottom of the car. About 10 x 15 cm, that must be welded with new metal.
First i believed the clutch was worn down, but it turned out that it was a combination of problems with the master- and slave cylinders.
Taking things appart and cleaning and lubing, and finally bleeding the system, and the clutch seems happy.
And the thermostat had to be changed.
And then a complete change of oil, oilfilter, airfilter, and coolant and a lot of bleeding.
But then its a quite happy little car, with (hopefully) just small optical snags.
Next weekend I'm gonna bleed the brakes, so all fluids are new and I know the quality all around.
  • Like
Reactions: Charlieboy13
Vehicle information
FIAT Cars
KaiserPingo
Views
3,077
Last update
More in FIAT Cars
More from KaiserPingo
