Extreme Hoover Sesh
Extreme Hoover Sesh
Perth, Scotland
Well due to the typical scottish weather i took time to finally gut out the car..firstly finding a garage to fit the supprisingly large GP into...
Then decide the seats were faar to big so out they came and the interior was cleaned, hoovered and blackened.
Such a good feeling having a clean interior again :D
Next step.....exterior polishing....when the weather improves
was a bit extreme of a clean but always good to do :D
ive negelcted the bravo so much its unreal as just dont really like the car anymore :D
mucho respect for that! The cinq could really do with that level of interior clean, but would likely start snapping off bolt heads :lol:
What did you blacken? Have very rarely seen inside a GP to know the difference
Just blackened all the trim so it looked showroom again. such a good thing to do specially as theres so much cheap trim on the thing. and talking about snapping off bolts, i ended up rounding one of the bolts putting it back in, for some reason was very difficult to put back in. ironically it was the passenger side, and usually the passenger weighs the best part of 19stone.....
So if anyone has a good way of getting a rounded bolt out please advice.
use a hacksaw or grinder and give it edges again or straight down the middle and uses a screw driver or bring it down to me as im on holiday and ill get it out for ya :D
ah torx bolts the joys :D
try if you can use a set of mole clamps i have both flat and curved up at the garage if you cant get hold of them as they may get it out with minimun fuss
i have these bits called irwin bolt removers and yes they do work , ive had pure rounded heads and the iewins still takes them out at just over £32 iirc its well worth it .. i can find the link if u want?
Yup, i'd use the same. I had similar problem with one of the cam cover on my 899 before.
Ming
