![]() | #1 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Throttle housing Hi all. Can someone assist me please. I have a 57 Panda 4x4. I had it into a garage because engine management light came on. After they hooked it up and ran diagnostic they told me it was issue with the throttle housing, they cleaned it up and informed me that if it happened again then I would need to replace the throttle housing! Away it happened again and the garage is struggling to get a good deal on one. Can anyone point me in the right direction.
![]() | #2 | ||
Posts: 26,429 Thanks: 1016 Trader Rating: 0 ![]() | Hi all. Can someone assist me please. I have a 57 Panda 4x4. I had it into a garage because engine management light came on. After they hooked it up and ran diagnostic they told me it was issue with the throttle housing, they cleaned it up and informed me that if it happened again then I would need to replace the throttle housing! Away it happened again and the garage is struggling to get a good deal on one. Can anyone point me in the right direction. ![]() Post in the Fiat Forums Panda section ![]() You want a good used one I assume For a new one try shop4parts Charlie
![]() | #3 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Re: Throttle housing Thanks Charles. Will do. Jim.
![]() | fender mender | Stilo | 5 | 30-03-2012 15:03 |
![]() | fender mender | Stilo | 8 | 25-02-2012 19:14 |
![]() | david295 | Punto (Mk2/2b) | 1 | 01-07-2011 22:14 |
THROTTLE HOUSING ON A BRAVO 1.6 | GAZ | FIAT Boo Archives | 7 | 09-01-2005 12:41 |
