![]() | #1 |
Posts: 263 Thanks: 13 Trader Rating: 0 ![]() | Hey, mr Vauxhall @Stuart, perhaps you can help My neighbour needs to remove the battery from his Meriva to get to his clutch but every time he disconnects it the power sounder alarm goes off. He's tried several things including trying disconnecting the battery within 10 seconds of switching off the ignition and nothing is working. Got any tips/tricks? Cheers
__________________ Grande Punto 1.6 Mjet in Exotica Red - the FS workhorse. Occasionally clean but usually full of boxes and other stuff. |
![]() | #2 |
Posts: 3,273 Thanks: 0 Trader Rating: 0 ![]() | Key in and turn to position 2 (lights on dash) Disconnect battery Open beer and marvel at a job well done. |
![]() | #3 |
Posts: 263 Thanks: 13 Trader Rating: 0 ![]() | Thanks for this and passed on the messages but apparently he's already tried that. He thinks there's an error with the alarm itself.
![]() | #4 |
![]() | 2 options, jump leads onto battery terminals, move battery and reconnect. Snip the wire to the alarm siren (or unplug it if it can be found), can easily use crimp on connectors to reconnect it if needs must. Where is the alarm getting it's power from to sound? either has to have its own battery or is using what's left in capacitors, in which case disconnecting then turning everything on will empty them in under 2 seconds.
__________________ www.fiat-scotland.com,the home of all things both scottish and italian. it's a bit like having an irn bru with your pizza, only much tastier ![]() 98 Fiat Cinquecento Sporting 16v, 94 Land Rover Discovery 300tdi |
![]() | #5 |
Posts: 3,273 Thanks: 0 Trader Rating: 0 ![]() | The power sounder is designed to do this, it has an internal backup battery, so if the wires are cut, or any 'unauthorised ' loss of power, it will sound. DO NOT tell him to cut the wire or the alarm will keep sounding. the procedure is: 1) ign to position 2 2) remove battey 3) remove key Key must be left in while the battery is removed If his only option is cutting the wire, he must remove the front passenger wheel and remove arch liner and the sounder is up in there. (Thats where it was on the Vectra but get him to google the location of the power sounder on the meriva.) when he sees it, he needs a bucket of water. Unplug power sounder and drop straight into water. This is a tried and tested method on Vectra B's, the Meriva may differ slightly. |
![]() | #6 |
Posts: 3,273 Thanks: 0 Trader Rating: 0 ![]() | Just had it confirmed that its ed Zachary the same as a vectra B, so go as above |
![]() | #7 |
Posts: 3,273 Thanks: 0 Trader Rating: 0 ![]() | Oh, did you get the txt by the way? hope the Nigerian number didn't confuse you too much lmao |
![]() | #8 |
![]() | ![]() The power sounder is designed to do this, it has an internal backup battery, so if the wires are cut, or any 'unauthorised ' loss of power, it will sound. DO NOT tell him to cut the wire or the alarm will keep sounding. the procedure is: 1) ign to position 2 2) remove battey 3) remove key Key must be left in while the battery is removed If his only option is cutting the wire, he must remove the front passenger wheel and remove arch liner and the sounder is up in there. (Thats where it was on the Vectra but get him to google the location of the power sounder on the meriva.) when he sees it, he needs a bucket of water. Unplug power sounder and drop straight into water. This is a tried and tested method on Vectra B's, the Meriva may differ slightly. Useless anyway, nobody pays attention to them. Weight saving ftw.
![]() | #9 |
Posts: 263 Thanks: 13 Trader Rating: 0 ![]() | ![]() Just had it confirmed that its ed Zachary the same as a vectra B, so go as above ![]() Oh, did you get the txt by the way? hope the Nigerian number didn't confuse you too much lmao And yes, got your texts thanks. The only confusing thing about them was they came from Nigeria and weren't asking to use my bank account to hide $60,000,000 :laugh:
![]() | #10 |
Posts: 3,273 Thanks: 0 Trader Rating: 0 ![]() | Zafira will be the same ![]() And the promise of $60,000,000 was going to follow up... i need you bank account details by the weekend though ![]() |
![]() | #11 |
![]() | aftermarket alarm on standard one
__________________ Blue Cinquecento 1242 15" Alloys, Lowered 60mm, 40mm Tb, McKcrich chip, Custom Door Builds Yellow Cinquecento turbo |
![]() | #12 |
Posts: 263 Thanks: 13 Trader Rating: 0 ![]() | ![]() Zafira will be the same ![]() And the promise of $60,000,000 was going to follow up... i need you bank account details by the weekend though ![]() That works much better on a calculator lol ![]() aftermarket alarm on standard one Not sure what the situation is tonight. I suspect nowt as he's got a runaround to keep him going and the car is booked in to a garage to deal with the clutch anyway. I certainly haven't heard any annoying beeping which is good Thanks for all the help though folks
