P0133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
bravo86gaz
FerrariInAffordableTrim
Edinburgh
A week into owning the Bravo and having problems already :shout:
basically, the CEL flagged up yesterday while driving although no other issues (loss of power, poor idle etc)
Read it today and got P0133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1) after a quick google this can be caused by anything from a bad sensor to exhaust leak to EGR apparently,
Looking through the history on the car it had the sensor changed back in Dec 14 and when I picked the car up last week it to get CEL reset for the o2 sensor
Think its worth changing again and would it make a difference whether its OEM or Euro Car Parts as I know cars can get fussy about what gets used, or digging about more ??
Check the exhaust for any leaks, moreso before the sensor. if all is good, get a genuine sensor and swap it out.
had the sensor out and it looked "OK" connector wasnt corroded/broken, sensor itself wasnt too dirty, couldnt see any signs of exhaust gas leaking from manifold, although the rest of the system had seen better days, joint at front to center pipe looked a bit iffy (looks like it should be a clamp but its been welded together), backbox outer skin has rusted to almost nothing and the rear metal hanger has broke
