bulb out
bulb out
weejock1979
Hi folks I have a bulb failure message tail light showing on the dash of the stilo have replaced all bulbs cleaned the contacts and it still appears is it now a case of a bad earth somewhere please help andy
If the lights still are not working then I would check the fuse and fuse contacts if you have not done already. If the lights are working but still have the dash warning try disconnecting the battery to reset system. After that I would go hunting for bad earth maybe a short or damaged wire. Hope this helps.
