Old 18-05-2014   #1
saw has donated!
loose connection warning
had this come up on dash at the same time engine cuts out. disconnecting + from battery and refit it works any ideas?
mk1 punto now
saw is offline Reply With Quote Quote
Old 18-05-2014   #2
I would just wiggle looms and see if it happens again, then once you have the right loom, go wire by wire.. narrow it down.
Stuart is offline Reply With Quote Quote
Old 18-05-2014   #3
Stick your own title
mrcinquecento's Avatar
mrcinquecento has donated!
Do you lose all electrics when it cuts out?
If so it sounds like the problem is perhaps the positive battery terminal itself, either the terminal or the wire to it.
If not.... I'm Currently doing the wiring loom on the cinq so i'll assume it's a similar setup power/ignition wise. If so there's also an ignition trigger wire connected to a bullet type terminal, which "should" be connected to a fuse (Maxi?), so it could be traced back from that to the connector to check that's secure, the fuse too, check that's not wiggling about.
www.fiat-scotland.com,the home of all things both scottish and italian. it's a bit like having an irn bru with your pizza, only much tastier
98 Fiat Cinquecento Sporting 16v, 94 Land Rover Discovery 300tdi
mrcinquecento is offline Reply With Quote Quote
Old 21-05-2014   #4
saw has donated!
no electric loss just engine cut out recovery said alternator faulty but i dont think it is, some think crank sensor but car runs locally fine. im not happy with terminal connection so i will look at that at weekend, MES has been mentioned also but as it needs windows 8 to run software i need to change pc soo im also thinking for £20 ish for crank sensor replacement would be easier and as i have nfi how to use mes anyway... Thanks Stuart & Mark
mk1 punto now
Old 24-05-2014   #5
saw has donated!
have new crankshaft sensor just need it to be dry to change it over, no happy about + terminal on battery still so ill look at that as well
mk1 punto now
Old 18-10-2014   #6
saw has donated!
replaced crankshaft sensor (just above starter motor) all fine since replaced
mk1 punto now
