Sorry folks this is going to be a long one but I want to try and provide as much detail as possible to help you diagnose the problem
For those who aren't familiar with it the car is Grande Punto 1.6 Mjet sporting on a 59 plate that has had radiator problems in the past and had a new radiator put in not long ago due to a leak
If you've been reading the site cars project thread you'll know radweld was put in both Yellow and my car last weekend. My car did a run down to Dunfermline and back the day after it was put in the coolant system with no problems - 120-odd miles each way btw. It has since done 30-40 miles a day again with no problem although I have noticed it getting up to temp a lot quicker than before the radweld went in.
I thought I'd dodged the bullet but last night on a run into Aberdeen I noticed the the needle on the temperature gage going up. I put the heater on and it did go back down to where it normally sits however on the trip back home and again going to Alford this morning it was fluctuating.
Luckily Malfunction's brother Colin who is a very experienced mechanic was also at Alford and he looked under the bonnet for me. The first thing he discovered was the cap for the coolant reservoir hadn't been put back on properly and was introducing air into the system. There didn't seem to be anything else obvious wrong and we did hear the fan kick in at one point so we know that is working.
We needed the car to get back home so headed off. The temp needle still fluctuated but didn't do so in what I would consider to be normal over-heating conditions. It started going up either going round a corner or up a hill but would return to it's usual position on a straight or the flat. It even sat perfectly still slap bang where it usually is when we were stationary in traffic for 5-10 minutes having previously fluctuated
Martyn suggested an air packet in the system when it happened the first time after Alford so do you experts think he's right? And if he is right will it be damaging anything in the engine? What can I do to shift it or does it need to go to the garage?
Help please
Help please
