Old 12-10-2011   #1
What cars use the same MAP Sensor, Coolant Sensor and TDC Sensors as 1997 1.1 Punto ?
Due to my ongoing problems with my car i was wandering if anyone knew what cars use the same sensors as my 1997 1.1 Punto Sx
I am after:
MAP Sensor,
Blue Coolant Sensor
TDC Sensor
As i went to my local scrapyard today and had no luck at all with Puntos
d1ckyboy is offline Reply With Quote Quote
Old 12-10-2011   #2
Stick your own title
mrcinquecento's Avatar
mrcinquecento has donated!
anything with an SPI 8v FIRE engine will have it, so certainly cinquecento sportings,sei sportings before 2001, punto mk1 55 and 1.2 60 will have the exact same sensors all over. later ones should do too tbh, but the early ones are definites
www.fiat-scotland.com,the home of all things both scottish and italian. it's a bit like having an irn bru with your pizza, only much tastier
98 Fiat Cinquecento Sporting 16v, 94 Land Rover Discovery 300tdi
mrcinquecento is offline Reply With Quote Quote
Old 12-10-2011   #3
Quote Originally Posted by Mrcento
Thought as much.
I best get on ebay and the internet then.
As there was bugger all apart from a Seicento 1.1 Sporting and 2 Mk2 Punto 1.2's
There was a C plated Uno, but that's a bit dated.
Old 13-10-2011   #4
Trader Rating: 3
ycming has donated!
All pre 1999 fire series engine (both 8v and 16v) share the same TDC (length wire will differ but will work and temp sensor)
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 15-10-2011   #5
Quote Originally Posted by YcMing
Ok cheers
How prone are the TDC Sensors for going ?
Old 18-10-2011   #6
Trader Rating: 3
ycming has donated!
I have replaced one in my life time. Worth trying if you have another !
Ming
