Okay, serious problems with the Sporting again!
Had the head gasket done last April...and then had it done again back in January and it has been running like a dream since then, until this week! I did however find that it had a hole in the top of the radiator. I now have a new radiator due to be fitted on Saturday!
On sunday it wouldnt start, it was turning over and juddering like a mofo. So I opened the radiator cap and closed it, and it started first time. For the rest of the week, the car has been juddery for the first 15 seconds or so on starting and then levels out. Heat from the blowers seems to be random, no matter if moving or sitting stationary, and the temp guage goes up and down randomly but never over the half way mark. I have been bleeding the system daily, thinking it was an airlock in the system. This seemed to help the whole juddering on starting the car.
Tonight however it wont start. On turning over the car the coolant pressure just builds up and tries to burst out the radiator reservoir! All 3 of the bleeding points then release loads of air. There had been a loss of coolant after driving it every time but i assumed that to be from the hole in the radiator, where I can see its been spraying out when hot!
the coolant is a lovely brown colour, but I assume that to be rust, etc.
Just been towed by the RAC and he said he'd put money on it being the HG...anyone got any other ideas?
I'd just like to think its a blockage in the cooling system causing all the pressure because I dont have any of the symptoms from the last 2 HG failures apart from the juddering!
I have also noticed tonight though that I have LOADS of oil in spark plug chamber 2 and a little in chamber 3.
HELP ME!!! Please!
HELP ME!!! Please!
