HGT Rear Brakes
HGT Rear Brakes
Ayr, Scotland
Hi guys, is there a guide etc kicking about for changing the discs and pads at the rear of the HGT, as took then off earlier today only to realise it was a screw in piston. So put it back together, until i get a tool. Halfords had a laser one at £20 but it didnt say it'd do Fiat or Alpha on it, anyone know where i can get one? Online or otherwise in the Glasgow area.
This is the same as the on in halfords
http://cgi.ebay.co.uk/Laser-Brake-Calip ... 0034231546
But also see you can get these which seem to do the same job for a lower cost:
http://cgi.ebay.co.uk/SYKES-PICKAVANT-P ... 0041319952
or
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... Track=true
The cube will do fine but you somtimes have to squeese them as well as turning it at the same time ie with water pump pliers
So the first one you pictured will be best as it pushes/squeeses as it turns it. its very easy and quick once you have sussed out how to use it
However when i used to do it I would use a large set of water pump pliers to squeese it whilst using a large plain screwdriver to turn it
Hope this helps you.
G
