found out that to get the most of my mods i'll have to replace the "common rail" injection system with the same from the 2.4 litre jtd engine in the fiat ducato vans, this will allow more fuel to flow in,as it is currently restricted by the standard ones,
so a summary, all intercooler,hoses and larger injection nozzles from 2.4 shall be gathered over next 2-3 weeks,then end of march me and my mechanical mates are taking off the cylinder head etc and taking it to precision engineering to be worked on.once complete the engine will be rebuilt with all the new upgraded parts,then a trip down to dastek to have the ecu re-mapped once more with again higher boost.resulting in a diesel which will eat up most things in its path.
to add to the pain for you petrolheads and pushing the boat out on diesel iv been e-mailing company's about getting a hybrid turbo made, BIG TURBO that can run upto 2.4 bar of boost,(36.5 psi). but that would require dry ice to be used to cool the intake air and a few other upgraded parts to cope with higher pressures. 250+ bhp and 400+ lb/ft of torque at 2500 rpm hmmmmmmm if it blows up i'll get the 2.4.
