My new Cinquecento abarth ( R ) now 1.2 MPI
When i had the P75 running on the SPI loom ,just splced at the injecor end , one that splits in to the 4 ... with ORANGE topped injectors , i had to leave a vac pipe off , just to get it to Idel , and it still ideled Realy rough , when i was coming up to junctions and put my clutch in it would sometimes cut out ,,, then when i went to re start the engine it would wind over and over aond over ...,
the only way i could get it at all good ( well better) was to leave the vac pipes off the back , them all and splice the vac pipe that comes off the pressure reg ,, ,
you need to upgade your fuel pump to the 3 bar Pump , you can find these on a lot of newer cars , 16 v punto , ect...
after i upgraded to pump made it idel a little better ,,
so i bought a P75 Ecu off a Good friend , got it posted to me and lucky enough it was Decoded, so plugged it in and fired it up , Instantly it was a million times better , no lumpy idel , no misfire, took it for a spin and there was no cutting out or nothing , it seemed to pull alot better on the 75 Ecu too ,, theres a couple of MPI ecus on Ebay ... theres a Guy on FF that if you have a socketed Ecu he will Write you a chip to decode your ecu and virginise it so that means you could plug it in and run it
Well due a update ,,
shes been running well since the last update ,,
strongflex Yellow wishbone and antiroll bar bushes fitted ,
and this week when ive been off this happend
Strongflex Red Rear trailing arms bushes fittted
Bigger rear caliper mounting plates
bigger Rear disks
New calipers (painted red for brintec points )
new caliper slider pins as old ones were worn
handles like shes on rails even better now ,,
oh and in outher news ,, ive found out she touches the limmeter in 5th when there was a vehicle behind me with stickers all over it :p "trying " to keep up :p
ohh and after all that found my fuel tank was leaking sooo brand new tank fitted awaiting pictures to be uploaded to my internet domaine then ill post them here
