imported_Ransoman
Member
- Jan 24, 2007
- 510
- 106
Introducing my new project. Before anyone complains it is not a Fiat, Well it almost is, the underbody is very much similar to the old Bravo afterall.
It was an MOT failure, the failure sheet filled 2 pages but the gist of it is the passengerside floorpan is rotted, rear brakes are knackered and the front wishbones have had it. The engine also makes a weird groaning noise which after a bit of prodding i suspect is power steering pump.
My plans are:
Remove all sound deadening (for weight saving and to access the rot.)
Learn to weld and fix the floorpan.
Do a light restoration on the whole underbody.
rebuild the rear brakes,
Replace the wishbones.
replace the timing belt leaving the balance shafts disconnected.
Few more pics:
Work started today and out came the interior and carpet:
under the carpet is a lot of sound deadening and underlay:
But in a few hours it was all done and the rust was exposed.
Close up:
This was the side that failed, and only 1 patch of the rust. The drivers side wasn't as bad:
My helpers for today:
A bit of sun last thursday so i grabbed the opertunity to do the front passenger side footwell.
I was surprised to see a lot of evidence of a coolent leak, the fibre insulation was sticky and pink:
I think this answers the question of why my floorpan was so bad.
It was such a hot day the tar mat just popped off the floor with virtually no effort:
This shows the extent of the damage in the Front Passenger footwell:
Whilst i was out there I had a quick check to see the power steering fluid as i suspect that the weird engine noise is the pump. Looks pretty bad:
Saturday
Today I tackled the drivers side. I was expecting an easy ride like the passenger side but no, The sound deadening material was different and was as pig to pick away at:
The stuff on the right was in all the other footwells and comes off easily and cleanly in large chunks, the stuff on the left has to be hit with a hammer and flat bladed screwdriver:
over an hour later it was clear:
only minimal rust too:
After all that I was left with a full bin bag of insulation and sound deadening:
I estimate this bag to be arround 15kg so that is a nice little weight saving. For info, i will be using foam floor covering to cover the footwells with after completion to dampen vibrations. I am going to remove all sound deadening with the exeption of the really thick stuff at the bulkhead. I am saving weight but i still want the car to be pleasant to drive.
Sunday
Under rear seats today:
Before
After.
The deadening on the left is the easy peel stuff, the deadening on the right is the solid tar-ey stuff. Slightly disapointed and how little this lot weighed, only a kilo or so but this had to be done as i didn't want to miss any rust.
Next weekend if i have the time the rear seat backs and all the side trim will come out. Then the whole floorpan from the rear seats to the tailgate will be wirebrushed to remove the rust, primered and painted.
